Page 3 of 3 FirstFirst 123
Results 41 to 54 of 54
    #41
    ungas, wut color ang 4000K ba? same as stock ba, yellowish or whitish? balak ko kasi palitan both ang headlight and fog lamps at hirap na hirap ang mag drive sa NLEX at aspalto at wala pang ilaw... nakaka takot lalo na pag umulan at walang lane markers...
  2. #42
    Bought first a PIAA (wala kang makita sa aspalto and 2x as expensive as Philips or Osram) then the Philips Vision Plus, +30% ito na halogen bulb. A lot better, stock 55w but mas maliwanag. After a few months I bought the OSRAM Silverstar which I think is one of the best sa mga halogen bulbs, +50% ito. This is what I am using now. I am satisfied now with my set up coz I have a Hella FF75 fogs for foreground illumination and the Comet 500 driving lights with Flosser All Weather h3 bulbs (maganda, 400 each before sa Infinity megamall). Of course HID would be better with Lightforce drive lights, di ba Prez Ungas? 50K yung set up na un. Baka mag Lightforce muna ako. May sale sa mga ibang US based 4x4 shops, ca. 10K for the 9.5".
    #43
    It is whitish hue, our Sun is around 5000K at midday so will have some color temp basis.
    3500K
    -Enhances red
    -Dulls blues
    -Adds yellow tint to white and greens
    3500-3900K
    -Basically neutral
    -Enhances most colors equally
    -Does not emphasize either yellow or blue
    4000K
    -Enhances blues
    -Dulls reds
    -Imparts bluish tint to whites and greens
    Feb 2004
    #44
    bought a pair of philips vision plus just the other day to replace the stock headlights of my gen2.5 pajero coz 1 bulb was already busted (driver side).
    i noticed that the stock bulbs were osram 100/80 (or was it 85) (contrary to what i thought would only be 60/55w) while i was replacing it with the philips that was only rated at 60/55W.
    anyways, (pardon an unobservant person) i first replaced the busted one and immediately compared the beam against a wall and i noticed that it was almost the same intensity. what caught my attention though was the difference in the beamwidth, of which the driver side was slightly narrower. when i replaced the right hand side, i did a comparo again and realized that the beamwidth of the right headlight was still wider even though i changed the bulb to philips which made me conclude that its the headlight projector causing that rather than the bulb. hehe, my ignorance, just wanted to share with you.
    and my question is, since the original bulbs were rated at 100/80, does that mean i can still change my bulbs to that rating without the need of any upgrade in wires or relays?
    is philips vision plus available at that wattage?
    anyone care to purchase a pair of one week old headlight bulbs?
    #45
    You may need to upgrade those wires if you intend to get 100/80 pairs. Based from your post, the vehicle is still good as new, and those bulbs should have lasted 1000 light hours more. Since it has higher ratings than stock 60/55 bulbs, current draw lacks and will need additional relay or relays to supply the electrical draw that your bulbs need.
    I remember on some website said that bulbs are designed for brightness and intensity, not longetivity, so any headlamp bulb purchase will be a tradeoff between these two factors.
    Jul 2004
    #46
    Originally posted by phillipogi
    I know na meron na nitong topic na to before...but I can't find it...
    Just wanna know, ano ok na super white bulb for size HB4? And ano pala yung bluish white na I see often nowadays sa mga sasakyan? Bulb lang ba yun or marami pang ginawa? Thanks!
    bro, alam kong medyo matagal na to.. pero tanong ko lang.. nakabili ka ba ng HB4 na white bulb? anong brand and ilan kelvins? ano kulay ng ilaw? thanx!
    Jul 2004
    #47
    3500K
    -Enhances red
    -Dulls blues
    3500-3900K
    -Basically neutral
    4000K
    -Enhances blues
    -Dulls reds
    bro.. paki explain naman.. yung mas simple.. hehe anong kulay ang labas ng 3500k, 3500-3900k, and 4000k?? thanx!
    Feb 2003
    #48
    i also want to ask kung anong klase headlight bulb ang pwede kong ipalit sa headlight ng ride ko..
    same stock wattage. anong klase and how much per bulb?
    Egg lancer EL
    #49
    poyang::: Any Kelvin measurement lower than 5000K will look the same as an ordinary halogen bulb. Medyo yellowish but not that yellow of a fog light. Use the 5000K or Sun's color for your basis. Anything above 5000K will produce colors ranging from whitish blue to bluish. Some HIDs with 10000K and above color temp can produce purplish light.
    bardigones::: Common H4 bulbs lang po yan, madaming klase at modelo na ang nagsulputan sa market. Unless nagpalit ka ng headlight assembly na hindi H4 ang bulb na ginagamit.
    Feb 2003
    #50
    meron po bang H4 bulbs na "mas malinaw" kaysa sa stock but i dont want to upgrade wires or any sockets or assemblies.
    hirap makakita sa gabi eh.
    #51
    Imo, stock na ang malinaw, umulan man o umaraw. Unless magpapalit ka ng higher wattage bulbs. Yung mga binebenta na 3950K halogens, mahirap pag wet roads. Kasama nag beblend sa tubig ang light reflections.
    Or instead of upgrading your bulbs, opt for relays installed on your headlight wirings, baka mas luminaw pa.
    #52
    sa nagtatanong kung ano yung mga differences ng color temps..
    got this from http://www.schorsch.com/kbase/glossary/cct.html
    1500 k Candlelight
    2680 k 40 W incandescent lamp
    3000 k 200 W incandescent lamp
    3200 k Sunrise/sunset
    3400 k Tungsten lamp
    3400 k 1 hour from dusk/dawn
    5000-4500 k Xenon lamp/light arc
    5500 k Sunny daylight around noon
    5500-5600 k Electronic photo flash
    6500-7500 k Overcast sky
    9000-12000 k Blue sky
    go figure....
    here is a better website to check out
    http://www.3drender.com/glossary/colortemp.htm
    for automotive purpose.. here is yet a better read..
    http://faq.auto.light.tripod.com/hl-hid-bulbs.htm
    Mar 2003
    #53
    which is better ba yung philips vision+ all weather bulb or yung OSRAM Silverstar(all weather bulb din ba ito)? and magkano ba ang mga bulbs na ganito na h4 size?
    Mar 2003
    #54
    the philips diamond vision bulbs are really crap. have some pics in my gallery comparing the stock h4 and the blue-tinted bulbs. the blue bulbs dont illuminate the road nor road signs better. it just appears "brighter" especially when u approach them head-on due to the glare the bulbs produce. =)
Headlight Bulbs
