Page 1 of 2 12 LastLast
Results 1 to 20 of 30
    Aug 2004
    mga pre i need ur advise kasi nagpalit ako ng headlight bulbs. yung "rainbow" type ang pinalit ko, pero nung binigay sakin yung bulbs nakalagay sa Label nya "platinum white" tama ba yun? anyway pinainstall ko na. nagkabit pa ng 2 relays malakas kc yung output. i tested it during night travel pero bakit parang di masyado maliwanag.. parang scattered yung ilaw.. di tutok. ano kaya remedyo gagawin ko? sa setup lang kaya yun?
    Feb 2005
    HIDs
    Jun 2004
    Get a projector headlamp, or go and get OEM bulbs (yellowish).
    Jul 2005
    return the product and ask for a refund
    Jan 1970
    Was it raining when you tested it ? Malabo kasi ang white bulbs kapag umuulan
    May 2005
    Quote Originally Posted by hagiber
    baka tinted pa ang windshield mo
    If you do a searcj, we have several topics touching on this already. Bottomline is "super white" bulbs don't work well in poor weather.
    ibig sabihin mali yun binigay saiyo dahil pag rainbow dapat yellowish siya..and hinde white
    Aug 2004
    depende rin sa brand yan... ano brand ng ilaw mo? kung white yan, wala ka talaga makikita lalo na kapag umuulan at tinted ka..
    would it be advisable to remove the diffuser of the headlight to maximize the beam of the bulb in my AE111?
    Dec 2003
    ang alam ko yellowish kapag rainbow type ang bulb.Balik mo yang super white kase wala kang makikita niyan kapag umuulan mahirap sa daan yan..
    yep..dapat yolloweish yun,all weather buld,baka nag ka mali lang,balik mo nlang.
    Aug 2005
    what happened if wlang relays ang mga malalakas na bulbs?
    Oct 2003
    it could burn your sockets and electricals right up to your headlight switches inside
    Oct 2005
    if you really want white light, try Wuerth plasma box. been using it since May, ok pa rin visibility kahit maulan. around P800.00 ang isa yung 100/80W. meron pang 130/90W.
    Oct 2005
    Quote Originally Posted by nixon75
    do you need to place relays when using these kinds of bulbs in particular?
    Jun 2004
    Make sure kaya ng headlamp housing yung added heat din ng 100/80 or higher bulbs. A relay would help, sabi ng iba grounding kit at ceramic sockets rin, pero this would depend on what vehicle you have.
    Kung added visibility during night time driving habol mo consider getting driving lights. I had driving lights installed and I am very pleased with them. I bought hella driving lights kaya medyo mahal (4k for a pair including installation) pero may cheaper options naman.
    ung white ko hinihintay ko na lang mapundi. ang hirap talaga pag umuulan
    Aug 2005
    waaaa! nag luko low beam and high beam ko.. last few months bumili ako ng bagong Headlight yung angel eyes tapos yung dalawang bulb pinalitan ko ng plasma white worth 1000+ up then hindi sinabi sakin kung nilagyan ng relay or wla.. di ko rin alam kung ano ang relay.. reputable nman ksi tinging ko sa shop nila..
    The problem is kpag mag high beam ako somtimes mag blue beam sa tachometer ko pero minsan nman hindi.. whats the problem going on mga bro sa wirings ko?
    Lately last week May umosok nasusunog na wirings sa loob ng tachometer ko parang umamoy sunog na fuse.. tapos nawala.. tapos wla nman na pundi sa light ko..
    whats the problem mga sir?
    Oct 2005
    umzzzzz, its a must to put relays when upgrading accessories. of course nothing beats standard yellow lights when it comes to visibility. jst speaking from experience using wuerth bulbs.
Headlight Bulbs
