Results 1 to 14 of 14
    Aug 2009
    I decided to start a new thread na lang so I can post the progress of my conversion here.
    I'll be using lexus LS430 projectors, one of the widest low beam only projectors available
    since the new projectors are low beam only, I decided to go with the 2005-06 headlights with a separate high beam. I bought myself a surplus set but when I tried to install them, they don't fit the 2003 bumper:
    Aug 2009
    that means either I chop up the stock 03 bumpers to fit or I go all out and swap the whole front end to the newer model.
    picked up a surplus bumper as well, in gold :D
    the grille and fogs are different as well so those are on the way as well.
    aba, nighthawk style yan ah bri_g! walang duda na maganda talaga ang bato ng ls430 projectors as i saw it in action nung nag-convoy kami ni nighthawk one time
    sir nasa magkano ang Bumpers ng 05-06 model ung surplus or taiwan model
    and san na kakamura??
    gusto ko dn ng MMC look ganda kasi ng grill at foglamps bilog...
    sana malaman ko ang pricing nito para mapag ipunan
    pang idol talaga. I'm 101% sure ganda nanaman kalalabasan nito
    May 2008
    one interested crv '03 owner here. looks like it's an expensive retrofitting.
    Aug 2009
    tagal ko na pala hindi naka update dito! its been a long 3 months using halogens hehe retrofit is finally almost done. hirap ng alignment since I don't have much room in the 06 crv headlights.
    here's the almost finished headlights:
    I had to run with 1 projector lang last night since the left headlight was aimed too high. 1 projector was enough to cover 4 lanes
    the lens swap gave the LS430 a nice sharp cut off
    output of the RH projector, left was not on.
    Aug 2009
    the nice sharp cut off
    the output of the right projector goes all the way to parking spot #6 (I'm parked in front of parking #2), could be wider if the white car wasn't there
    thats about it! should be done by end of this week.
    Aug 2004
    ser galing galing. congrats on your Mod....
    BTW, paano ba ginagawa yung ika-cut yung old reflector
    and in with the new one? if not too much trouble. puede some pix?
    also how to Rewire the harness fm. H4 to a 4lamp system? (need to replacee din ba yung Light switch on the stalk?)
    huling tanong nga pala...yung donor lights mo ng 2005CRV eh local model or JDM surplus?
    Regards,
    Aug 2009
    Quote Originally Posted by parakitoJDM View Post
    Regards,
    thanks sir! I'll take a pic sa next project ko. you basically cut up the reflector para kasya yung projector kasi you're basically bolting down the projector to the reflector.
    rewiring will depend per car yung ibang h4 kasi uses 2 positives 1 negative or 1 positive and 2 negatives. no need to change the light switch stalk, tap ka lang from the stock h4 harness.
    in my case local model na crv galing yung headlights ko (may nakalagay din LHD) pero it wouldn't matter if you're doing a retrofit since yung reflector will be used to mount the projector lang naman. important yung projector ang LHD. HTH
  11. #11
    iba tlaga LS430. nice pics bri! i'll let you know later kung nag affect ba tlga yung lens. it looks like from your pics hindi nawala yung side output.. mukang kelangan ng more tuning pa yung lens ko.
    Jun 2010
    Pre marunong ka magkabit ng fx-r projector? patulong naman bigyan kita ng labor,
    ^ Nighthawk and garyq are the known people here who do retrofitting.
    Jul 2006
    nice project. interested akong makabitan yung crv ko kaso di ako nakakahanap ng malapit lapit na gumagawa dito sa bulacan either luluwas pa ko ng maynila o sa pampanga pa.. anyways congrats sa result
CRV hid retrofit + 03 to 05 swap
