Results 1 to 3 of 3
    Jan 1970
    Guys currently Im using 90/100W na super white bulb... lately napansin ko my rpm dips from 900 to around 700 if I turn-on the head light... check ko alternator ok naman the engine still runs with out the neg. and pos. terminal of the battery.... Ano kaya problem nito, should I need to install relay... diko pala alam kung ilang amp ang alternator if stock pa ba to..
    Thanks for the help!
    a relay MIGHT help.
    but since ang taas na nang wattage ng bulbs mo, i suggest that you do install one.
    wirings should be thicker than stock.pag nasunog yan baka may madamay pang iba.
    and dude...click the "SEARCH" function sa upper right ng window..then type "HEADLIGHT".
    dami nang threads about this.thanks!
    Jan 1970
    Originally posted by GlennSter
    a relay MIGHT help.
    Thanks for the speedy reply dude :-) Search muna ako...
HEAD LIGHT Related Problem
