Results 1 to 6 of 6
August 24th, 2012 11:47 AM #1
Pls advice where to buy quality head lamps for L300. i want the clear one.
kindly post the brand, price and the store (pref. in binondo area).
thanks
August 24th, 2012 12:34 PM #2
are you using sealed beam or h4? if the original is sealed beam, good inexpensive replacements are available in auto supply stores. i read that some aftermarket clear units scatter light.
August 24th, 2012 01:46 PM #3
August 24th, 2012 01:58 PM #4
the size i'm looking for is 200mm x 142mm
something like this
Tsikot Member Rank 3
- Jul 2004
- 1,540
August 24th, 2012 02:54 PM #5Not sure how much or where exactly you can find it, but I'm sure you know the new L300 comes with clear lens already. This should be an improvement over your original lamps and should give a good light pattern.
There are some stores in Masangkay and Benavidez that sell Mitsubishi parts. You can ask if they have it or if they can order for you
- Jun 2010
- 33
September 11th, 2012 08:36 PM #6
thank you its good naka timing chain pala. yan din concerns ko sa used car like sa dati kong...
