Page 1 of 2 12 LastLast
Results 1 to 20 of 40
    Jul 2006
    mga sir
    ask ko lang kung pwede ko palitan yung stock headlights ko
    AE101 Corolla 1997 Big Body.
    Specs ng stock: 12V - 55W
    gusto ko sana palitan ng: Higher Wattage Headlights yung
    nabibili sa mga malls na Lightbulb yung tig P400 pair yung 300Watts ata un
    pwede kaya? any modifications or salpak na lang?
    ty po
    Quote Originally Posted by sirmykel View Post
    mga sir
    ty po
    you don't change the actual assembly per se.
    ang gagawin dyan is i-uupgrade yung wiring, and lalagyan ng higher relay tsaka papalitan ng ceramic sockets to withstand the higher temperature ng bulb.
    Jul 2006
    sir di ba kaya ng bulb lang papalitan ko?
    wala akong babaguhin sa assembly yung bulb lang talaga
    300W? tunaw ang lens cover mo niyan for sure...
    and masakit yan sa mata for incoming drivers on the opposite side of the road. please give due consideration to other road users. 55/60W is more than adequate unless you are sporting super dark tints in your front windshield.
    Aug 2004
    100W pa lang minsan tunaw na ang sockets or worse sunog ang switch.
    hindi yan kaya ng stock sockets tsaka ng stock wiring.
    Feb 2006
    ask ko na rin sir, di ba may 55/60 watts pero 90/100 watts daw. pwede kaya yun at di na ba kailangang mag upgrade ng wiring??? tnx
    maximum of 80/100W lang safe isalpak sa stock wiring and socket.
    i suggest mag Osram Silverstar ka, stock wattage but throws more
    than ordinary H4. you can also do a search, re headlights upgrade
    for more options/suggestions.
    Aug 2004
    Quote Originally Posted by evs_13 View Post
    Emphasis on the DAW. Usually may tint lang ang bumbilya para magmukhang puti. Lalong nababawasan ang light on the road. Mahal pa naman. Stick to stock
    Feb 2006
    ok, napundi kasi low beam ko, h7 sya. so i will go for osram silverstar?? magkano kaya yun? may ibang kulay ba ng H1 (hi beam) saka H7(low beam) aside from the stock na white??
    Sep 2004
    Honga, I don't think there's such a thing as a 300watt bulb for automotive headlights. Kung meron man nun, grabe ang pagkasilaw nun, it would be deemed illegal
    Aug 2004
    All-weather yellowish color. Meron din ata Narva and Osram neto.
    Sep 2006
    Don't go too much off the standard wattage. I personally hate those bluish/whitish high wattage HL's. They're too bright and even if they are aimed right (sa low beam) nakakasilaw pa rin sa ibang motorista (which is dangerous).
    I see others as "for porma purposes only"
    Jul 2006
    naku sorry po kasi yun nakita ko sa mall.
    maybe napo ako bibili nun.
    ask ko na lang kung meron bang white bulb na 55/60 Watts lang?
    kung meron po san po ung reliable na tindahan at brand
    Jul 2006
    IMO stick to stock wattage bulbs and aim your lights properly. There is a tutorial on www.danielsternlighting.com on how to aim the lights correctly. If you have foglamps, do the same!
    Number one cause of glare is misaligned headlights, especially those with front end accidents kung san nag tilt yung headlights dahil sa tama. This is also the number one reason why people cannot see properly, both on the receiving or giving end.
    ACE Hardware sells the Osram bulbs, very good bulbs but a bit pricy. Still worth it, IMO.
    Makisawsaw lang po. Paano i-adjust yung headlight? masyado kasing mataas at nakaturo sa kanan.
    Sep 2006
    Meron pong adjustment bolt/screw usually sa likod ng headlights. Yung iba dalawang adjustment each HL, right-left tsaka up-down. Yung iba naman up-down lang. Try your owner's manual.
    white bulbs are worthless.
    Sep 2006
    Quote Originally Posted by mazdamazda View Post
    E ang blue bulbs?
    Aug 2006
    Quote Originally Posted by Galactus View Post
    Bro, mayron nga 400/450W. Yong BMW 7 series at MB na 2006 S at E series dito puro matataas ang ilaw. Pati na yong tail at brake lights nila nakakabulag. Kaya pag may nasa likod ko noon o nasa harap ko, nag iiba na ako ng lane dahil sobra talaga.
Stock Headlights replacment
