Results 1 to 7 of 7
    Aug 2003
    hb4 or hb3 ba ito? yung sa dim light
    mag how much ang ordinary bulb intend to
    to upgrade kasi to 100watts
    Feb 2003
    vin888, if you will upgrade your headlight bulbs to 100W, better check your wiring harness, the OEM wires might not be able to maintain the 100W.
    go to Autoline and look for Alex, he sells the 100W bulbs and suggest you buy an aftermarket wiring harness for your 100W headlight bulbs.
    Aug 2003
    thnx fr3d3rick =)
    what kind of bulbs ba yung low and high beam nito?
    Feb 2003
    I'm using the all-weather NARVA brand. 60W ata ang low beam or maybe the same lang but brighter output. I bought an aftermarket wiring harness also to be safe. Better ask ALEX na lang. HTH.
    Aug 2003
    nag ask ako sa banawe kanina. highest daw sa mga ordinary type bulbs 70w lang hb4 if i want higher watt dapat bilhin ko daw yung mga pair na bulbs like philips etc
    Mar 2004
    sa akin 65w lang ang low, ordinady bulb lang. planning to buy a higher wat.. din. medyo malabo kasi yung dim ko sa left eh.
    Jul 2004
    vin888 mas ok..nman yung mga philips na pair bulb mhal nga pero mas malakas nman yung mga output lalo na pagsuper white ang pinili mu mas ok..yung brand na cats sa pair bulb nde pa mabilis mapundi
h. accord headlight bulb
