Results 1 to 10 of 17
- Aug 2003
- 9,720
October 29th, 2007 02:13 PM #1hi all,
certainly not one of my better driving days today...
things started out as normal when i drove myself to the office to get some stuff i left behind. nung paalis na ako ng car park, i heard this scraping sound from the engine bay. since i've been hearing some squeals under the hood for weeks now, akala ko baka one of the belts were just scraping against the plastic cover of the timing belt.
i then went to V-mall, hearing the scraping sound all the way going there. nung pauwi na ako, i suddenly noticed that the 'check oil' lamp was going on/off intermittently. i pulled up at the nearest gas station and bought a liter of oil for refilling. the weird part is that i was still within the safe level. i added it anyways just to be sure.
from the gas station going home, the scraping sound seemed to disappear whenever i revved the engine up to a certain rpm. wala naman akong maramdaman sa loss in power, only up until the last 50-100 meters from home. mga dalawang beses ako namatayan, and parang nakulang sa hatak even at 1st gear.
i'm suspecting that the oil pump may be at fault here. What do you guys think?
Any chance that i may have damaged anything inside the engine?
October 29th, 2007 02:27 PM #2
that sound bad. Maybe ur engine is starting to seize up.
potential damage to crankshaft, main bearings
- Aug 2003
- 9,720
October 29th, 2007 07:56 PM #3i've been some of the other threads...they don't paint a pretty picture
what other telltale signs should i look for to confirm if any damage has been done to the internals? duda ko baka nag iintermittent lang ung oil pump, and has not totally conked out...kung hindi e hindi na ako umabot ng bahay...
...or maybe i'm just in the denial stage right now :p
October 30th, 2007 09:13 AM #4
well, that "dalawang beses ako namatayan" is already telltale signs.
wag mo na gamitin ung car. the engine might stop dead in the middle of the road.
the main bearings are grinding on the crankshaft with no lubrication.
Dude, think metal to metal with no lube. What happens?
October 30th, 2007 11:36 AM #5
scary situation. that's why i've been toying w/ the idea of installing an oil pressure gauge. you guys think it'll be of help? especially to older cars such as my ek?
October 30th, 2007 01:49 PM #7
^where can you have that done? mga magkano kaya? matagal ba ang installation niyan?
October 30th, 2007 03:19 PM #8
Ouch...
If your oil level is normal, I'd say your pump is either dead or your oil lines are "barado". It's telling that the sound goes away when you rev the engine. Oil just isn't climbing up.
But if you're hearing scraping, that's the death-rattle of an engine on its way out... condolences...
- Aug 2003
- 9,720
October 30th, 2007 09:25 PM #9sigh...tried to start up the engine kanina...a definite clang-clang-clang of metal on metal
meron po ba kayong marecommend na shop near pasay/makati? ung sanay mag(gasp) overhaul.
pwede bang ipatow ung ride ko to the talyer? how much usually ang charge?Last edited by badkuk; October 30th, 2007 at 09:31 PM.
October 30th, 2007 09:29 PM #10
sir badkuk ,di kaya kayo nalubak at tinamaan oil pan tapos tumapat ang yupi ng oilpan sa oil pump.kaya di na maganda higop nia ng langis para makabomba
ito kasi naging culprit sa Vanette ng Pinsan ko ..after nalubak umilaw na sa dash ang "check oil lamp" pero di nia pinansin andar pa din sia .pero dalawa beses sia itinirik .andar uli malapit na kasi sa bahay nila
naka uwi naman ,kinabukasan ayaw na mag umandar engine nia,tukod na piston dahil sa walang lubrication .wala na kasi nag pump
ng tinggnan ang ilalim nakita ang oil pan may yupi
Kami dati naglalagay ng chain lock ng motor or bike. Iba nakita ko literal na kadena at padlock.
