Results 1 to 15 of 15
    Sep 2005
    Diba peeps, bago i-start ang sasakyan hinihintay muna natin magchange iyong temp light from Red to Blue? Baket ganito pansin ko 2 beses na nangyari sa akin ito eh, nung iniistart ko na iyong sasakyan (from originally red hinintay ko lumipat to blue so ok na) bumalik ulit sa Red iyong templight then blue ulit. Nangyari ito noong nagsastart na iyong engine. Nangyari na ba ito sa inyo? Warning sign ba ito ng kung ano man?
    Sep 2005
    Meron pala akong idadagdag, may kulang pa!
    Noong iniistart ko na iyong sasakyan napansin ko din na iyong fuel indicator ko nagturn off (nagpoint sa empty) tapos noong nag on na iyong makina, normal na ulit - fuel indicator pointed upward (kung saan iyong normal nyang fuel level at that time) at iyong red temp light nag shift na ulit to blue.
    may tanung lang ako. why the need to wait for the temp light from red to blue?
    Jun 2007
    red is malamig pa ung makina and blue ready to go na..or vice versa. haha
    Dec 2003
    bago daw istart...not when started na..
    Sep 2005
    Quote Originally Posted by afrasay View Post
    Sabi kasi sa manual hehehe.
    Intially from a coldstart red sya then mag bublue. Blue indicates that the engine is still cold, after several meters mawawala iyong blue ibig sabihin nun normal na iyong temp.
    Sign ng overheat ang red, so for example nagtatravel ka na with the temp lamps turned off tapos nag red ibig sabihin nun nagooverheat na ang makina mo.
    Quote Originally Posted by froshie1 View Post
    Ah ok. Thanks for the info. So you have no temp gauge on your meter cluster? Just an idiot light.
    Sep 2005
    ^yeah true. But isn't it that even the conventional temp meter once the hand raises above the normal level it's already a sign of an overheating engine?
    That's what I experience in my old Nissan California and my dad's Galant Super Saloon. My dad's car though has a few minutes of leeway before it shoots up to the top but as far as I know even if it's pointer is not in the normal position that's already a sign of an engine overheat.
    Aug 2007
    possible na battery yan, kasi dati nung naubos na battery ko nag punta sa full yung needle eh, nung nag park ako 1/4 tank lang. Tapos malaman ko na lang naiwan ko pala bukas yung fog lamps at na discharge na yung battery. maaring symptoms na yan ng malapit ka na magpalit ng battery. Kung may alarm yung sasakyan mo, baka rin alarm.
    Sep 2005
    ok for those Vios owners out there na 1.3 J. symptoms ito na papatay na ang batterya. so kung nakita nyo ito magpacheck na ng battery.
    Wala bang temperature gauge ang Vios?
    ^parang sa jazz siguro hot and cold icons lang ang nasa cluster gauge
    Dec 2002
    Quote Originally Posted by mazingerZ View Post
    Too bad wala ngang temp gauge, puro indicators lang (hot and cold - parang shower hehe).
    Nov 2003
    i say let it be...
    ito ang explanation ko diyan
    during initial start up, light red wait maging blue bago start:
    during this period kaya at first red :starting sequence ay power up test para macheck muna kung everthing is normal.
    if test is normal ligth turn to blue means engine is cold, then you can start the engine.
    during starting fuel gauge goes to empty maybe due during this stage all of the battery power is diverted to the engine to ensure engine start.
Vios owners help! Weird behavior of temperature warning lights.
