Results 1 to 13 of 13
    Aug 2005
    gusto ko ng palitan ung stock bulb ng civic ko.
    1. anong magandang ipalit na bulb? gusto ko sana ung mas maliwanag kaysa sa stock.
    a)bosch? b)narva c)osram d)philips
    2. kapag nag upgrade ng bulb ano ung mga kailangan palitan? at idagdag?
    3. usually magkano dapat ang budget ko?
    4. recommended shop near las pinas or bacoor,cavite area?
    (pasensya na mga bro's newbie talaga ako eh)
    Thanks in advance!!!
    Quote Originally Posted by Nash26 View Post
    1. narva all weather
    2. the socket should be changed to ceramics. also, the wiring should be re-routed para magkaroon ng sariling relay.
    3. hmmmm. dunno. mga 2k?
    4. i can refer you to a shop owned by my college classmate sa philamlife vill, las pinas. or look for mike sa sunguard stall sa motortown, atc.
    Jun 2007
    1. Im currently using osram all weather 80/85 (higher watt than stock)
    2. 100% agree with 1D4LV you should change to ceramic, did you notice even stock socket melt? I do
    relay also would be a great help
    3. it depends on what bulb you purchase, this is my breakdown on my purchase
    ceramic sockets 150
    osram all weather 80/85 H4 480x2
    total = 1110
    4. wala ako marecommend bro near your area pero may marerefer ako maybe talk to him if you want to deliver the goods at your doorstep at kung kayang kaya mo mag DIY pm me if you do
    ^bro, kailangan pa ba ng relays and socket changing kung osram silverstars lang ang ilalagay?
    kung higher wattage ang ipapalit mo compared sa stock wattage, dapat palitan ang sockets and install relays para walang premature burning ng wires and sockets due to higher temperature and electrical load.
    ^ganun ba? i think i read here somewhere before that headlights w/ osram silverstars don't need to have their wire and sockets up graded. medyo confusing
    anyway, thanks bro
    Aug 2005
    1D4LV , washburn, salamat sa mabibilis na reply! Mag papalit na ako ng all weather bulbs next week! thanks ulit sa inyo!
    anyway, thanks bro
    as i've mentioned, basta mas mataas ang wattage sa stock, you need to.
    you have the option not too, but of course, the stock sockets will melt, the wires, which can handle so much current and heat, may deteriorate...
    anyway, thanks bro
    No need to be confused bro, I’m using Osram Siverstar with my stock sockets and wirings. Osram Silverstar comes only in stock 55/60W. Even my Bosch all season 80/85W has no problem with it.
stock civic headlights
