Results 1 to 8 of 8
    Apr 2012
    Hi,
    Gusto ko sanang palitan ang bulbs ng fog light ng picanto ko ng yellow bulb. Meron po ba kayong marerecommend na bulb na hindi madadamage ang housing ng fog lights? Meron po bang all weather na H27? TIA
    May nakita ako dati sa banaue na yellow bulb na H27 881. pero hindi philips or osram. Never ever use other bulbs higher than 27 watts or kahit HID. masusunog at iitim ang housing sa loob. Problem is 27 watts is too low. pero all hyundai and kia vehicles use Phillips H27 881 bulbs as fogs
    Quote Originally Posted by gherule View Post
    Hi,
    Apr 2012
    Hi Uwak! May nakita akong euroline at solarzen kaso nag hesitate ako kasi nakalagay 27w=60w. I got confused baka kasi mashado shang mainit and may cause damage sa housing. Yung solarzen naman nakalagay "it can create brightness of 50w" sa website. Noob po ako sa kotse pero will it produce more heat kung totoo na 50w ang output nya. TIA
    same with elevo, 27w => 65w
    up for the question
    I don't really know. May nakita akong naka yellow fogs na hindi HID but may discoloration lang. If the wattage sez 27W but with 65W light output. siguro ok lang. as long as talagang 27W lang. Phillips, Osram at GE lang ang nakita kong May H27.
    eto ba yung nakita mo?
    [ame=http://www.amazon.com/Solarzen-Driving-Headlight-White-Package/dp/B005JFLSAW]Amazon.com: 881 (862 884 889 894 896 898 899 H27 W2 etc.) 15 SMD LED Bulb Fog/Driving Headlight Xenon White. Pair Retail Package: Car Electronics[/ame]
    Jan 2008
    Quote Originally Posted by seymorebutts View Post
    up for the question
    better check the wattage imprinted on the metal base of the bulb.. that is its true wattage... 27w is the power consumption but the output is equivalent to 65w.. some bulbs use special gas to make the ordinary 27watts bulb shine as if it is a 65watts bulb
    Up for this topic. I'm looking for a pair myself.
    Hi,
881 yellow bulb
