Results 1 to 12 of 12
    Oct 2015
    So i have been looking through their works at their pages, but i cant really decide.
    Anyone that is willing to share any feedback regarding them?
    TIA
    Quote Originally Posted by apt2a View Post
    TIA
    Have you read through this thread?
    Planning on getting an HID retrofit
    Jun 2011
    TIA
    FEEDBACK Expensive....
    Keon Sobra Led... is brighter at a fraction of a cost..
    5k lang
    Oct 2015
    Quote Originally Posted by ssaloon View Post
    thank you sir for pointing me to the correct forum.
    Dec 2014
    5k lang
    Sir sa anung kotse po nakakabit? Pashare naman sir ng interior pic with low beam on if hindi hasle. Thanks
    Oct 2015
    5k lang
    I compared KS led installed on a Landcruiser 80 (with clear reflector lens) and Hilux Revo with my hid projector retrofit. Malayo ang difference. Cutoff pa lang mas matingkad and defined ang HID. Mas malayo din bato ng ilaw pag bright. 😎
    Nag scatter ang light sa LEDs so go with the hid retro. Worth the price imo. Here's a pic of my stage 1 retro from garyQ. Tint : 3m dark
    Dec 2014
    Quote Originally Posted by aar0nix View Post
    Sir have you tried testing led on the isuzu oem projector?
    Oct 2015
    Quote Originally Posted by hypnos View Post
    Yes I already tried Philips LED. Not made for projector use. Nagkaroon ng scattered light lalo dun sa squirrel spotter area.
    Dec 2014
    Thanks for the immediate response Sir. Will opt for retrofit then.
    Oct 2015
    You're welcome
    Also check out Xenon Concepts (facebook). Stage 2 nya Php10k lang. Everything included na. Wiring is all plug and play, neatly tucked.
    Mar 2012
    Both GaryQ and redline are good retrofitters. Compare mo sa mga ibang cheap plug n play projectors yung mga gawa nila is way better ang light output. Mahal pero sulit ang output.
    Nagpa retrofit ako dati sa redline at ok naman ang trabaho nila medyo na disappoint lang ako na at that price I was expecting a morimoto ballast pero hindi yun ang ginamit nila so mas na nauna pa na sira amg ballast kaysa orig na philips 85122 d2s 35w.
    Kaya ngayun mag DIY na lang ako sa bagong unit ko. Naka projector na cya pero bitin ako so im planning to replace the projector na mka accept ng d2s dahil nka d5s pa ang stock bulb ng unit ko now which di common at 25w lang.
    Planning to order parts direct from TRS sa US.
    Sent from my SM-J710GN using Tapatalk
GaryQ, Firedrake or Redline for HID Projector Retrofit
