how to DIY on changing signal light ng 96 EK civic?
Which signal light? Bulb only or are you planning on changing the unit istelf?
If you're talking about the cheek lights, sinusundot lang palabas yung lens and kita mo na yung bulb.
signal light ba sa headlight assembly? well, may mud guard yung fender- no actually, the wheel well. it is (mud guard) was secured by a clip, just remove the clip then slightly move the mudguard, there you would be able to access the back of the headlight assembly. twist and replace the bulb. then place the mudguard back by securing it with clips. voila!
*fedski, di pa tayo nag-abot sa YM. you see me online, just buzz me. i'll send the file to you. ok? thanks!
