Results 1 to 11 of 11
    Feb 2006
    guys, for example, the bulb says 55W input but gives a 100W output. should you consider getting relays and thicker bulb wires? yung iba kasi electrician sabi sakin no need since stock 55W ang input.
  2. #2
    mga ganyan gamit ko, philips crystal vision in: 60/55, out 120/110w...
    no need for relay, kasi stock lang consumo nya.....
    Feb 2006
    ah ok, pero pumuputok yung fuse ko. what seems to be the problem? i'm using raybrig H3 55W output 90W
  4. #4
    yan ang prob ko noon..fog light ba? originally may fog ba siya? o wala? baka may dikit yan(grounded...)
    Jul 2006
    Those lights only have stock wattage (60/55) but look like 100W.
    Kung pumuputok, it may not only be 55W as advertised, but something higher.
    Mar 2005
    The most and effective way to determine the required fuse protection is to measure the actual amperes. Remove the fuse and insert the leads of the ammeter (ask from electrical shop) in place of the fuse. If the reading varies, then there is something wrong with your wiring. But if it stays constant, then probably you have to increase your fuse rating to next higher.
input/output bulb wattage
