Results 1 to 12 of 12
    Apr 2010
    Hi mga tsikoteers,
    just wanted to ask assistance regarding my foglamps.
    It has a metal shield covering the bulb and since metal siya and bulb is hot, now the metal shield now looks like a burnt metal. (color rainbow to brownish na)
    can this be cleaned? or is it more advisable to remove the shield na lang.
    thank you in advance for the assistance.
    btw, it looks almost like this.. (you can see the bulb shield already dark, pero sakin is a very light brown.. parang nag sisimula na siya masunog)
    Jan 2009
    Try removing the shield nalang (if possible). Fogs shouldn't be a problem with glare, unless aimed wrong. Also, if the shield looks burnt then there's something wrong. If you leave it too long it might cause more damage.
    May 2009
    yung mga bagong fogs wala nyang reflector... although not sure if nakakasilaw na sya pag tinanggal mo kasi it is mainly for focusing the beam.
    baka naman sir nagpalit ka ng high wattage na bulb kaya nasunog? although pag ganun usually ang unang masusunog is the harness pag stock pa rin...
    Apr 2010
    thanks for the reply mga sir.. to answer your questions, nope, I haven't changed the bulbs, the bulbs installed is what is included in the foglamps, H3 55watts.
    then sa installation, its directly connected to the battery and then relay as well.
    i think this is one of the 'manufacturing flaws' of my foglamps, just saw another pair a few days ago ng palabas ako ng village, parehong pareho kami ng nakasalubong ko and it also has that issue that I have.
    ill try first to clean it with a typical metal polish... if all else fails, then ill first remove one side and see if it will give a blinding glare sa kasalubong ko.. hopefully not kasi mababa ang installation nya sa bumper ko.
    Jul 2010
    di na ba sakop ng warranty yan bro?
    Apr 2010
    di po siya kasama sa vehicle.. add on ko lang po..
    but it also crossed my mind na pwede ko siguro ipakita sa pinag-bilhan tsaka nag kabit sir.. thanks sir desertfox for that option!! di ko naisip yun! (sobrang dami ko kasing iniisip eh.)
    Jan 2009
    Quote Originally Posted by olidotcom View Post
    Their counter-argument maybe that the burnt marks appeared due to wear and tear which in some cases isn't covered by warranty.
    Apr 2010
    good point din sir.. malamang my 'plan b' is either to try to use metal polish if it can be removed.. else, permanently remove the shield.. buti na lang the surrounding reflectors did not turned the same color due to heat of the bulbs.. plano ko pa naman mag palit ng higher wattage ng bulbs.
    Jul 2010
    ah, accessories na lang pala bro. kung gayun, malamang wala na warranty yan sa pinagbilhan mo, alam mo naman kapag electrical items...pero malay natin me ginintuang puso ang may ari ng store na pinagbilhan mo,alang alang sa diwa ng Pasko....try mo din....
    Apr 2010
    Quote Originally Posted by desert fox View Post
    hahahhaa... baka di na ko kilala nun.. baka i-deny na dun ako bumili.. dibale.. may plan B pa ko..
    Jul 2004
    The problem could also be the bulb itself. I remember when I had the foglights installed in our Sentra Grandeur, the michiba bulbs included in the package (stock 55watts) seem to run so hot that it made the foglamp lens cloudy. Changed the bulbs to philips h3 and problem was gone. Also noticed upon removing the michiba bulbs that they were almost burned out after just 2 or 3 months of usage with minimal use of foglamps
    Apr 2010
    Quote Originally Posted by glntVR View Post
    thanks sir. ill check them as well.. baka nga din pangit yung stock bulbs na kasama.
Foglamp light shield - 'burnt'
