[SIZE=2]
Question po regarding sa bulb na H3 Xennon all weather 150w. mag melt po kaya ung loob ng fog lamps ko and do it need to replace the wiring nun?
TIA!!!
mods, paki merge na lang po if may same thread na...
[/SIZE]
if you increase the wattage of your bulb it's best that you also change you wirings para hindi masunog yung stock wirings mo. kailangan din magpalit ka ng ceramic socket.
This weekend ko lang napansin na Xennon H3 150w ung nasa label nung bulb. Kaya nagulat ako. Just want to avoid any future damage it might cause.
Sorry EK fog lamps po sha. Nung binili ko sha it came with all the wirrings. then bumili na lang ako ng bulb. so tinanggal ung stock. Correct me po if im wrong. Ksi nung binuksan walang socket. wire ksi ung end ng bulb. thanks po..
di ba yun H3 wala ng syang socket, the bulb itself is mounted on its metal base plate which yun ng yun ground and there is a wire for the +12 volts. Wiring harness lang upgrade kapag hi wattage yun bulb nyo as well as the foglight housing itself, baka tunawin yun mga hardplastic na foglamp housing and lens.
