aside from CASA since it's too expensive.
bro you can get DLAA units from Concorde or sa Banawe but frankly speaking, these fog lamps are really useless in real world driving![]()
hi gary,
would changing headlamps improve my visibility. i have smoked 3M tints in my windshield. would a plug and play H4 bulb or HID help?
DLAA is pretty good. wag lang malakas ang ulan at magkaka moisture sa loob. pero if it's turned on, mawawala din naman.
Definitely changing your headlamps would improve visibility. But not JUST by swapping HIDS from Halogen. Doing that can cause ANNOYING and BLINDING glare to oncoming motorists. And usually, plug-n-play HIDS just can do so much. To maximize the output of HIDs, I'd say go through GARY's RETROFIT. Check his works under " Lights & Lamps " Talk section. Impressive works. Sharp cut-offs = no glare. Worth the buck, if I may say.
Foglights don't help so much. Yes, functional but it's more of an aesthetic thing.
desertfox: bro I am not responding to your query just to sell my services. I mean if you go that route, it's fine with mehehe but I really would like to provide actual info on upgrading your lighting setup. Definitely dont go for plugnplay HID. Not worth it in my opinion coz you will glare other motorist and the output is so-so. I also woudnt suggest the fog upgrade like the DLAA. 3k din kasi yun tapos improvement sa lighting mo, dun sa area that would really help you see further down the road, is minimal. Get first a good halogen bulb if i were you then no tint kung pwede or light-medium tint lang. The best output you can get is of course from a projector na HID. save up for it na lang
