Results 1 to 16 of 16
  1. #1
    Guys,
    I'm having this problem where my signal lights will suddenly blink wildly. Sometimes it's ok sometimes it will blink wildly. My hazard function is ok. This problem is intermittent.
    I experienced this on my 98Gli during rains and never on dry conditions. But with my exalta 2000, it's happening both in dry and wet conditions.
    Need help. Any inputs will be highly appreciated.
    regards,
    city
    Aug 2004
    Busted bulb/s or busted blinker relay or shorted wires.
    usually indication yan ng busted bulbs.
    Signature
    yup palitan mo na madali lang i-DIY yan.
    Jan 2003
    kapag hindi naman busted, pangit yung bulb na nakalagay. tyr mong palitan yung bumbilya
    Aug 2004
    May effect din pala ang pangit na bulb? Kaya siguro medyo erratic din sa akin hehe
    sa signal lightbulbs kasi 2 or 3 point yung contacts nya. pag di maganda yung contact or pagka-fit or may prob na yung contacts nawawala sa timing yung blinking. palit bulbs ka na yung original para fit talaga.
    Aug 2005
    Check mo rin baka may moisture yung contact between bulbs sa receptacles.
    ibig sabihin niyan bilisan mong lumiko he..he
  10. #10
    Quote Originally Posted by kimpOy
    hahahaha...thanks guys!...kimps...medyo parang nadadala nga ako pagbumibilis yung blink!....anyways....thanks for all you inputs..i'll try and see if replacing the bulb will make it go away...i'll keep you guys posted.
    regards,
    city
    Quote Originally Posted by city
    regards,
    city
    while you're at it, linisan mo na rin yung sockets kasi sometimes they build up oxidation which causes erratic operation. good luck!
    LOL!
    i agree.
  14. #14
    Quote Originally Posted by FXT
    thanks FXT!
    city
    kung hindi sa blinker bulbs ang problema, pwede din dun s blinker relay switch (yun nga ba tawag dun). I experienced it before and had the thing replaced. the trick is finding where that blinker relay/switch is located. It's usually under the dashboard, or bunched with the other relays under the hood inside your engine bay.
  16. #16
    rsnald...thanks for the input..will check that too.
    regards,
    city
ERRATIC Signal Lights!
