Results 1 to 20 of 24
    Aug 2013
    Anyone know where I can buy LED turn signal lights? I'm specifically looking for one with on a BA15D/1157 socket with a switchback function (dual light, amber + white). Also, would those stores also sell the accompanying load resistor for the LED bulbs?
    From what I know, most cars will cause the signal lights to hyperflash when using LEDs without a load resistor because the car thinks the bulbs are burnt out. Burnt out bulbs = lower load. LED bulbs = much lower load than filament bulbs, so car thinks it's a burnt bulb. Is this still true or have they come up with turn signal LED bulbs that don't require a load resistor anymore?
    Additionally, I believe OBD2 tools (like those Bluetooth/wifi OBD2 interface that connects to your smartphone) can clear the "burnt bulb" error to prevent the hyperflashing. Has anyone tried this instead of using a load resistor with their LED turn signal bulbs?
    Btw, these LEDs with switchback function would look like this. If not using the turn signal or hazard lights, they would function like DRLs.
    Jun 2015
    There's someone in miragepilipinas selling something like that. Check their forum.
    sent via Tapatalk
    Oct 2013
    in my opinion, mas ok pa i-LED ang brake lights kase pag may OEM keyless entry ka, ma visual check mo naman kung busted ang signal lights mo every time you lock/unlock your car... the cost of a 20-40 pesos filament bulb vs LED is just way to off...
    Jan 2009
    I ordered two pairs of 1156 yellow LEDs together with an aftermarket variable-speed flasher relay from eBay. Putting load resistors is such a brute-force approach as they tend to heat up. I decided to just replace the OEM flasher relay. Plug-n-play and no wire splicing. Items are scheduled to arrive sometime next week or so.
    I already have the brake light mod using 1157 red LEDs. I'm also going to replace the T15 high-mount brake lamp to a red T10 LED.
    Aug 2013
    Yes, having a load resistor defeats the purpose of the LEDs being efficient. But I'm after the switchback function and unfortunately, I've yet to find out if my car still uses a flasher or if it's regulated by the ECU. If it's regulated by the ECU, I suppose one of those OBD2 chips can clear the error to eliminate the hyperflashing.
    Jan 2009
    You may be able to clear the DTC temporarily but if the error condition still exist, you're likely to receive frequent notifications about burnt bulbs.
    You probably need those LEDs that has CAN bus decoders. They're no more than LEDs with built-in resistors, or so I've read.
    Oct 2007
    I replaced my stock turn signal bulb to Philips Ultinon LED, bakit kaya mahina siya compared to stock bulb? I installed a canbus to avoid hyperflash as suggested by the seller, mali ba kag install ko?
    Jan 2008
    Parallel dapat yung resistor.. baka naka series
    Oct 2007
    I'll check tomorrow, thanks!
    Oct 2007
    Searched the internet and sad to say that Philips Untinon amber is not that bright, lot of people in some forum complained that it's too dim, if you want a brighter led bulb, buy the Philips xtreme ultinon and not the regular ultinon led bulb.
