Results 1 to 17 of 17
    first of all this is not for porma or anything, more for safety as an early warning device if ever i need to stop in a highway at night.
    i just added last month a set of fog lamps at the back (under the bumper) which is paralleled to the back up lights. i needed more light kasi when backing up inside our garage at night, so this only operates when the gear is in reverse.
    when i opened the rear lights to connect the fog lamps to the back up light wiring, i noticed that there are no extra leads for upgrades or additional lights. so question, do you guys know of the location, if any, of extra wirings going to the lights, especially to the back? or do i need to add the wires myself? i will be installing the strobe lights inside the hazard lights in all 4 corners. sa harap dali na lang mag-add pero sa likod medyo malayo kasi and i will need to pass the wire under the chasis. any suggestions where to pass the wires in case i will need to wire it myself? i will also be installing a switch on the dash pero dali na lang yun.
    car is a lancer mx 2002 but i suppose this will be a generic thing so baka applicable din yung sa ibang cars. suggestions please, especially from those who have strobes installed. thanks.
    Jan 2003
    Yebo, sa tingin ko you'll have to put a new wire from the battery to the rear, and have it relayed na lang. lagay ka fuse nearest to the positive terminal battery, in case of a short.
    I have stroble lights inside my reverse lamps.
    You just need longer wires. The wires pass through the interior for weather protection. The only time they go outside the vehicle is thorugh the grommet on the firewall.
    Generic Taiwan lang po. Php 350.00 sa ACE hardware. Kaso I still have some splicing and soldering to do. The kit is not wide enough for my rig so I have to extend some wires.
    yun din ikakabit ko yung sa ace na cheap, baka blue strobes sa harap and red strobes sa likod.
    so wala talaga lusot, i really need to wire it up from the dash to the lights. ok, at least i'll be busy for 2 days hehehe! work 10 minutes, rest 1 hour, work 10 minutes, rest 1 hour hehehehe!
    Mar 2004
    meron yata ako nakita sa SM workshop na strobe lights na maliit lang di tulad nung ibang may casing pa. para cyang yung bulb lang na nakasabit sa wired and yung main box nya is nasa labas. it looks like blasting caps ng dynamite. Mas gusto ko to ksi i thik its easier to install ilalagay mo lang sa loob ng headlight / tail light yung bulb and nasa labas yung main blinker module nya.
    nakita ko na din yun, mas madali nga ikabit. drill lang ng hole sa housing then seal with silicone. muntik na nga ako bumili 2 weeks ago kaso naholdap ako
    ng mrs ko! waaah!
    You do not need to drill holes. Just pass the wires where thru the hole where the bulb passes through. The wires are thin enough so that you can re-install the bulb socket without fuss.
    I'm just using white for now. Yun kasi ang most visible.
    Okay lang po ba magkabit ng strobe lights kasama ng reverse light??
    and okay lang po ba maglagay nito for warning purposes while at stop?
    thank you...
    wow tagal na nito nahukay mo pa ehehehehe!
    ok lang siguro, 2 years na naka-install yung sa akin e. yun lang nga very seldom ko ginagamit, pag needed lang talaga like pag naka-stop ako sa heavy traffic area. basta wag ka lang install ng wangwang.
    Alala ko lang po noong na flat ako sa Canaba Viaduct, hindi pa ginagawa yung NLEX so wala pa yung assistance na matatawagan at nasa kalagitnaan na ko ng bridge at gabi pa nun. YUng flat-tire panaman nasa rear driver side, so everytime na may dadaan na truck para akong hinihigop...inabot lng yata ako ng 10mins. maximum na cguro yung 20mins sa pagpalit ng flat-tire, dahil sa sobrang kaba..ehehhehe
    Oks.. for emergency warning purposes lng, while at stop.
    sabay ko cguro sa switch ng hazard or individual switch para hindi pagtripan ng police..
    Thanks for the reply Sir Yebo
    Last edited by Satio; August 23rd, 2006 at 12:45 AM. Reason: I didn't press the preview post =)
    balita ko underbody neon daw yung next project mo ninong
    Jun 2007
    saan ba merong mura at magandang strobe lights na pang headlight? ung ubulb type na ndi madaling masira.. gaya ng type r....?? ano pong brand and ung pang grills din na strobe saan po makakabili sa banawe??
    Pwede, kahit nga taxi meron hehehehe lalo na mga scooter
    Jun 2007
    maganda ba ang code red? or evolution? or ysdz type r? fusion? or max5000
    Quote Originally Posted by Kapitan View Post
    Strobe lights, as the threadstarter mentions, should only be used as a last resort when stopping in the middle of the highway.
    Using these while driving normally to bully other motorist is not acceptable here.
    Quote Originally Posted by orionz3
    For what purpose would you be using strobelights in your headlamps?
    Jun 2007
    Quote Originally Posted by mazdamazda View Post
    sa motor ko po ilalagay.. ndi mismo sa headlamp, ung headlamp type na strobe para kasya sa park light ng motor ko... kse dati akong fire volunteer.. ndi sa inaakala mong mambubully ng ibang motorist sa kalsada ang purpose ko.. alam mo naman na ang motorsiklo lalo na kng ndi bigbike eh ndi gaano visible lalo na ngayong tag ulan at gabi.. mahirap makita.. kaya kahit konteng warning device lang na mapansin ng maige... tsaka pag may responde at naka tail ako sa truxk namin during responde sa sunog...
adding strobe lights in all 4 corners
