Results 1 to 10 of 17
September 2nd, 2004 11:45 PM #1
first of all this is not for porma or anything, more for safety as an early warning device if ever i need to stop in a highway at night.
i just added last month a set of fog lamps at the back (under the bumper) which is paralleled to the back up lights. i needed more light kasi when backing up inside our garage at night, so this only operates when the gear is in reverse.
when i opened the rear lights to connect the fog lamps to the back up light wiring, i noticed that there are no extra leads for upgrades or additional lights. so question, do you guys know of the location, if any, of extra wirings going to the lights, especially to the back? or do i need to add the wires myself? i will be installing the strobe lights inside the hazard lights in all 4 corners. sa harap dali na lang mag-add pero sa likod medyo malayo kasi and i will need to pass the wire under the chasis. any suggestions where to pass the wires in case i will need to wire it myself? i will also be installing a switch on the dash pero dali na lang yun.
car is a lancer mx 2002 but i suppose this will be a generic thing so baka applicable din yung sa ibang cars. suggestions please, especially from those who have strobes installed. thanks.
September 3rd, 2004 12:02 AM #2
Yebo, sa tingin ko you'll have to put a new wire from the battery to the rear, and have it relayed na lang. lagay ka fuse nearest to the positive terminal battery, in case of a short.
September 3rd, 2004 10:29 AM #3
I have stroble lights inside my reverse lamps.
You just need longer wires. The wires pass through the interior for weather protection. The only time they go outside the vehicle is thorugh the grommet on the firewall.
Generic Taiwan lang po. Php 350.00 sa ACE hardware. Kaso I still have some splicing and soldering to do. The kit is not wide enough for my rig so I have to extend some wires.
September 3rd, 2004 11:35 AM #4
yun din ikakabit ko yung sa ace na cheap, baka blue strobes sa harap and red strobes sa likod.
so wala talaga lusot, i really need to wire it up from the dash to the lights. ok, at least i'll be busy for 2 days hehehe! work 10 minutes, rest 1 hour, work 10 minutes, rest 1 hour hehehehe!
September 3rd, 2004 12:40 PM #5
meron yata ako nakita sa SM workshop na strobe lights na maliit lang di tulad nung ibang may casing pa. para cyang yung bulb lang na nakasabit sa wired and yung main box nya is nasa labas. it looks like blasting caps ng dynamite. Mas gusto ko to ksi i thik its easier to install ilalagay mo lang sa loob ng headlight / tail light yung bulb and nasa labas yung main blinker module nya.
September 3rd, 2004 02:02 PM #6
nakita ko na din yun, mas madali nga ikabit. drill lang ng hole sa housing then seal with silicone. muntik na nga ako bumili 2 weeks ago kaso naholdap ako
ng mrs ko! waaah!
September 5th, 2004 09:25 PM #7
You do not need to drill holes. Just pass the wires where thru the hole where the bulb passes through. The wires are thin enough so that you can re-install the bulb socket without fuss.
I'm just using white for now. Yun kasi ang most visible.
August 22nd, 2006 10:18 PM #8
Okay lang po ba magkabit ng strobe lights kasama ng reverse light??
and okay lang po ba maglagay nito for warning purposes while at stop?
thank you...
August 22nd, 2006 10:46 PM #9
wow tagal na nito nahukay mo pa ehehehehe!
ok lang siguro, 2 years na naka-install yung sa akin e. yun lang nga very seldom ko ginagamit, pag needed lang talaga like pag naka-stop ako sa heavy traffic area. basta wag ka lang install ng wangwang.
August 23rd, 2006 12:44 AM #10
Alala ko lang po noong na flat ako sa Canaba Viaduct, hindi pa ginagawa yung NLEX so wala pa yung assistance na matatawagan at nasa kalagitnaan na ko ng bridge at gabi pa nun. YUng flat-tire panaman nasa rear driver side, so everytime na may dadaan na truck para akong hinihigop...inabot lng yata ako ng 10mins. maximum na cguro yung 20mins sa pagpalit ng flat-tire, dahil sa sobrang kaba..ehehhehe
Oks.. for emergency warning purposes lng, while at stop.
sabay ko cguro sa switch ng hazard or individual switch para hindi pagtripan ng police..
Thanks for the reply Sir YeboLast edited by Satio; August 23rd, 2006 at 12:45 AM. Reason: I didn't press the preview post =)
UK, Oz-wide JB74 fuel pump recall. Check Suzuki Ph for VINs affected. Sent from my SM-S901E...
Suzuki JIMNY [merged threads]
