Results 1 to 12 of 12
    Guys recommend naman po kayo ng mga shops that can replace the dashboard lights for my car. Yung iba po kasing lights nya pundi na tapos yung iba naman feeling ko lumalabo na din.
    TIA and more power to tsikot
  2. #2
    x2: yung can diy that. ano ba ride mo? yung mga bulbs sa mga surplusan or auto supply madami.
    yup.. agree with the post above. dami sa banawe kayang-kaya yan. or pwedeng DIY yan.
    Dec 2003
    dali lng yan DIY, n maganda dyan u learn something bout ur ride
    baka kailangan lang nating mag-eyeglasses pare ko
    Jan 2003
    pwede rin may problema ang electrical system.
    Oct 2003
    or maybe its just dirty..if you have the guts and know how..DIY na yan..pero if you dont want to take the risk..go to a shop na lang and ask them to replace it for you, if indeed thats the problem..
    wonder how can i make my dash's illumination white? green kasi ngayon eh
    hehehe thank you sa mga input nyo mga bro's gusto ko nga sana I DIY kaso mukang magkakalas ka ng mga part ng dashboard hehehe. Sir M54 Powered malinaw naman po ang mata ko hehehe, sige mga sir ask na lang ako sa banawe kung pano magpalit, sabi kasi sakin sa ibang forum pede mo pa daw palitan ang mga lights nun kahit color red or green.
    Mar 2005
    Quote Originally Posted by x2pher
    Most of the problem comes from contacts (like switches) and sockets. If it can observed that the magnitude of brightness is not constant, most probably loose connection lang iyan. If your dashboard lighting is controlled by rheostat, it can be on this section.
    Quote Originally Posted by busy road
    Good point! thing is some parts of the bezel gauges has absolutely no light at all! So I pretty much assume that most of the lights were totally busted, Anyway its a 5 yr old AUV, I sure hope I can find a service manual so I can change it myself. Thanks bro
    Jan 2003
    usual practice, pagawa mo muna. then observe kung pano kinakalas n assemble. para next time kaya ng DIY =)
    Oct 2003
    I usually bring my car to my bro in law's shop in San Juan. He has a very good electrician that can replace all bulbs and at the same time clean the unit including the glass. Make sure to change all the bulbs ( mura lang naman ) so all lights will be equal. Sometimes I even upgrade the bulb to a higher wattge but the same size and change the color of my dashboard. You can call him at 09155463089 and look for louie.
Dashboard Lights getting blurry.
