Page 1 of 3 123 LastLast
Results 1 to 20 of 46
    Jun 2005
    Help, im planning to buy HID conversion kit, what brands to watch out, problems and comments specially those who are using HID
    Feb 2005
    I have an XTec kit that I bought locally, but I did see at available at a hardware store in the top level of Shangri-La Mall when I was in Manila recently. Xtec comes with a lifetime warranty but, if I remember correctly, is somewhat expensive (P20,000 I think).
    Jun 2005
    Nice, lifetime warranty. i'll try to find that brand
    I went to Banawe and saw different brands like Blesk, Helios, Plasma, Mcculloch. Also they have diferent mechanism for having high beam thru up and down movement of the bulb, forward and back, some have halogen bulb as their bright.
    Dec 2003
    Quote Originally Posted by bluntman
    wow!!.... ok yan ah.. for 20k not bad... lifetime warranty..
  5. #5
    Check out Philips or Osram... in the world of automotive lighting these two brands are on the top 2.
    Jun 2005
    Quote Originally Posted by ILuvDetailing
    Philips, ive heard some of the Hid kits uses philips bulbs and ballast, the only problem is they "rebase" it for it to fit (ex. h1-h4). Some would also say that philips does not truly make a conversion kit but rather have the 2 on them (refering to the bulb and ballast).
    Mar 2005
    ok yun xtec ah. mahanap nga yun.. lifetime warranty...
    brands that are ok....
    plasma, mcculoch, super vison, xenon-bulbs... ok tong mga brands na to... pero still have to check the xtec brand....
  8. #8
    baurtwell: naka HID ka ba? hehehe Yung kakilala ko nagkakaproblem sa McColloch, namamatay. IMO overpriced yung Xenon-Bulbs.
    Apr 2005
    nka hid(h4) ako , i think its a xtec brand , my problem is ayaw mag high ito (mechanism push type)after long use , i think me problema sa mechanism nito(parang stockup,kailangan laruin mo pa yun lever many times too change low to high beam) , change my bulb many times (3x) na same problem exist ,sabi sa akin ng supplier yan nga yun problema ng hid ,kung mag papakabit ka tanung mo kung anong type yung bulb kit dual bulb mechanism type. di ko pa na try yung dualbulb type kung same problem , pero sa mechanism push type yan ang na experience ko
    Jun 2005
    I was eyeing on buying mcculloch HID, because it was US made and AFAIK does not use push type mechanism... Namamatay ba? bakit kaya?
    * axelangel007
    I was also thinking of that problem for push type mechanism......
    OK YAN lifetime warranty, but saan mo pwede papalitan? sa hardware store sa shangri-la do they willing na palitan pagnasira?
    Aug 2004
    sulit ung Xtec for 20k if lifetime nga!!
    Jun 2004
    pag hi low madalas talaga nagkaka problem..kahit yun akin ganun rin dati..
    Apr 2005
    palagay ko yun mechanism niya me problema ehh parang naiipit, hindi naman siya namamatay kaya lang i have to push the lever up and down many times para lumipat sa high beam kasi mga kasalubung ko puro signal me switch too low beam siguro kasi lakas ng headlight ko.
    ive heard na yun mga unang labas na hid 2002 up me problema sa hid kailangan uminit bago mag function yun mga light(kaya siguro namamatay), 2003 ko pa nabili yun hid ko di naman namamatay yun ilaw yun lang after using it for how many months ayaw mag switch too high .
    yun nagkabit at nabilhan ko ng hid ganun din ang problem niya , kailangan laruin yun lever para gumana yun low to high beam hid,
    then he tires a new brand xenon mechanism type too , sabi niya ala panaman problema,the last time ive ask him this yr last march.
    Jun 2004
    maganda un hid na may dalawang bulb..nx beam ata un brand...
    Mar 2005
    yup. naka hid po ako... (h4) pero planning na magpalit ng brand.. still thinking kung ano...
    yun din ang madalas na problema pag hi/low ang hid... yung flicker mechanism nya ang nasisira... xenon-bulbs medyo overpriced nga...
    ok din ang brand na prizm, eagle eye... pero sakin parang may catch kung lifetime warranty yan.. baka kasi sirain yung unit eh.. yun lang...
    Jun 2005
    I went to Shangri-La, xtec's price was around 29,000 and its not lifetime warranty... only 6 months warranty
  18. #18
    san ba made ang xtec?
    Jan 2003
    Quote Originally Posted by Rev-0
    ok yan ah 29k tas half a year pa ang warranty, alam ko HID 1 year ang mga warranty.
    Mar 2005
    sad to say... not quite a good deal... just 6 mos. for that kind of price... kasi usually 1 year warranty ang mga hid's overpriced pa sya kaysa sa xenon-bulbs ah. at least ang xenon.. 1 and a half year ata ang warranty or mas matagal pa...
HID Conversion kit
