Any shop would you recommend for headlight cleaning and restoration?
Napansin ko lang its the headlights that usually oxidize, but the tailights are more resistant.
Pag shop, I think they just use rubbing compound & buffing wheel on the lenses, or DIY kit lang din (see below). If you don't apply sealant afterwards maninilaw nga lang ulit.
Nag restore ako ng headlight of one of our 13 year old cars using a DIY kit. Best results are achieved using kits with a polish separate from the sealant, rather than 2 in 1 products na restorer/sealant. Depende sa degree ng oxidation (grabe yung sa amin- neglected nung gumagamit) the lenses will clear up, but it won't be the same as yung crystal clear ng brand new. Tumatagal naman as long as you re-apply the sealant at regular intervals like wax (monthly works fine in our case).
I omit mentioning brands if possible, pero marami ka makikita sa DIY hardware or car accessory shops, so if nagtitipid ka, prices are around (300-700) for a kit. It won't take an hour of your time to fix.
If you buy new lenses naman, waxing the headlights along with the body helps delay oxidation din.
Remember to apply UV protection sealant after polishing the headlights ...
Required ba pltan seal if inopen headlights for the 4th time?
DIY
less than 500 php sa materials [emoji106][emoji106]
if oxidized lang and no deep scratch .
1. sand 1000 grit
2. wash then alcohol rub
3. sand 1500 or 2000 grit
4. wash then alcohol rub
5. sand 2500 grit
6. wash then alcohol rub
7. spray 3 coats of uv resistant clear coat
8. wait for 24 hours, as much as possible do not use
9. sand grit 3000 (or 2500 if not available), do this lightly (matanggal lang orange peel)
10. polish
btw i tried wash and alcohol rub
then rubbing compound, then polish sa altis ng neighbor ko
aftern 2-3 months may sign na agad na mag oxidized pero i think ok pa ito for a year bago lumala.
^ sorry noob question. San ka nakakabili ng mga sandpaper from 1000 - 3000 (pwede din ito sa scratches sa relo diba). Pati yung uv clear coat? Try ko gawin 'to.
yespo.
but don't forget the anti-UV protection, lest we do it again after a few months, like what i did.
nag-sawa na ako sa kaka-polish, i bought a pair of replacements. they're plug n play, except that the adjusting screws need at least 10 times the screwing, to effect the minutest movement.
