Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 55
    Aug 2014
    #41
    Yung 100 watts ba na bulb hindi ba nakakalabo ng headlight? Sobrang init kasi kapag nasalat yung headlight
    Dec 2009
    #42
    Quote Originally Posted by timming_gear View Post
    pag ginamit mo yan 100watt na bulb especially if hindi UV block quartz yung glass (cheap ones) with plastic lens it will degrade and darken the plastic lens faster.
    kung glass ang headlight lens mo, you an get away with it.
    Aug 2014
    #43
    Quote Originally Posted by miko101130 View Post
    Bali sa lowbeam ng Fortuner ko sir kinabit. Binalik ko ulit sa stock ang init kasi talaga baka masira yung Projector. Sabi sisirain din daw yung socket.
    Dec 2009
    #44
    ah... oo mainit talaga 100watt lalo na sa confined space kung sa projector mo pala ilalagay sa low beam..
    ang maganda nyan ay pa retrofit mo projectors ng fortuner mo.
    Feb 2011
    #45
    pfft. Tried using the older Phillips XV, it barely lasted half a year. Currently using Osram NBU bought from powerbulb, hopefully it last longer. I know brighter lights (in same wattage) usually dies faster but at those rate, I rather save for a proper retrofit
    Jan 2013
    #46
    Hi guys, planning to replace our car's stock low beam bulbs, ano po ba maganda for provincial highway roads na madilim? The car uses projectors btw, mag 1 year pa lang this September.
    We replaced the HIDs with Bosch all weather bulbs sa isang sasakyan ok naman siya. Maganda din kaya Fog breakers sa projectors? I rarely use the foglamps din kasi mababa lang naman di nakatutok. Thanks.
    Jun 2012
    #47
    At 2600K, masyadong madilaw ang Fogbreaker sa headlamps. Kung gusto mo ng dilaw, try mo maghanap ng Philips Weather Vision. Mas puti ng kaunti at 2900K.
    Jan 2013
    #48
    I see, how about Nightbreakers sir? Madami na pala bago like yung unlimited or extreme ba yun? Ok lang ba sila sa almost unlit roads?
    Jun 2012
    #49
    According to their manufacturers,
    Nightbreaker Unli: 20% whiter, 110% more light than regular stock halogen
    Xtreme Vision: 10% whiter, 100% more light than regular stock halogen
    #50
    Had Nightbreaker Unlimited bulbs for my car before, noticeable improvement compared to my stock halogen headlamps, but definitely not a 110% improvement. More like 20%:
Brightest Halogen Bulb
