Page 1 of 2 12 LastLast
Results 1 to 20 of 34
    saan nakakabili nung novus or norvus bulb? diba pwede one piece lang yun? and how much, super white and yun all weather????
    Jan 2003
    Novus is Germany made bulb, super white comes in pair I bought one before sa Autospecs Banawe Tel.723-3835 OR 414-2463 Ask Mabel Chua, Php500.00 pair, 12V/100W super white. Ewan kung nagbebenta ng isa lang, meron ako 12V/55W Super white, 1 pc. kasi napundi yung kapares, I can give it to you for free if you like, Alabang Filinvest ako.:D
    clone
    try mo rin icheck out ang HANS TOOLS sa shangrila, katabi ng true value... don ako bumili and they offer bulbs per piece with a lot of brands to choose from...philips, narva, hella, etc. they also offer raybrig pero set yun.
    at least dito siguradong orig yung binibili mo
    HTH
    clone1537,
    thank you for the offer!
    ssaloon,
    how much ba yun pag per piece, mga ballpark figures?
    i got my philips all weather bulbs with stock wattage at P180/bulb
    Jan 1970
    pardon my ignorance and my lack of diy skills, but how do i change my headlight bulbs? include changing bulbs for park lights and signal lights as well. my car is an ae101 corolla. thank you very much.
    ps. sorry if i hi jacked this thread :oops:
    spazzkid::: Mahihirapan ka sa driver side headlight, masikip ang pwesto. Yung sa passenger side tatanggalin mo lang yung water reservoir lusot kamay na. Pero I'd be extra careful kung di mo kabisado yung lock ng headlight bulbs. Delikado hawakan ang lens nito at baka magasgasan. Pratice ka muna sa parklights, di maselan ang bulbs nito. All you have to do is remove the whole park light housing to be able to reach behind it. 10mm turn to your left will unlock the bulb. Yung sa signal light naman ganun din ang turn, wag ka matataranta pag ayaw sumindi ang ilaw. Peanut bulbs have positive and negative contacts, babaliktarin mo lang ayus na. :D
    Jan 1970
    pareng ungas, salamat ng marami pre. i will keep your suggestions in mind. one last questions. if i want a brighter and whiter light, what voltages/wattage/amperage should i get? also, what are good brands that are a bit cheap. salamat ulet mga pre.:mrgreen:
    i suggest you stick to stock colored bulbs. super white bulbs have very poor visibility when its raining, delekado lalo na't rainy season na.
    i used to have philips diamaster headlight bulbs. same input of 55w/60w pero output is 100w/110w. be sure to have a relay kit installed as well as thicker wires to accomodate the higher output. i now use philips all weather bulbs with stock wattage kasi pundi na diamaster ko. lifespan nung ginamit ko was about 1-1.5 yrs i think.
    good luck!
    Quote Originally Posted by spazzkid
    pareng ungas, salamat ng marami pre. i will keep your suggestions in mind. one last question. if i want a brighter and whiter light, what voltages/wattage/amperage should i get? also, what are good brands that are a bit cheap. salamat ulet mga pre.:mrgreen:
    Hmm.. Voltage should still remain in 12V, if you can still source for the old Flosser 135/110W bulbs the better, but I doubt if auto accessories shop still carry these stuff. As the guys always post, never forget to change all the headlight wirings additional relay and a cearmic socket. IMO, cheaper bulbs will only last 6 monts to a year. But the PIAA brand will cost you much more, there are Raybrig bulbs that are cheaper priced but be also aware for some fake ones. Many users have attested to stick with an all-weather bulb (yellowish color) for better visibility during downpours.
    For the brighter and whiter light, I would normally suggest an HID kit which will cost you about 20-30thou. But then again you requested for a more cheaper option. :D
    I just use either Philips stock white na 90/100W or Philip All-weather na 90/100W on our rides... very cost-effective. Flosser 90/100W all-weather is also good.
    osram all-weather pare okay sya!
    osram silverstar, stock color stock wattage pero better /farther light throw on dim & bright setting (compared sa stock)
    philips vision plus, medyo whiter sa silverstar, stock wattage, slightly better lighting than silverstar.
    as experienced by the peeps at HCP.
    Jan 2003
    Quote Originally Posted by vinj
    where can i buy this philipps/flosse bulbs?
    Jan 1970
    thanks for the suggestions guys, i wrote it down and see if my local auto shop carries one of these. again, thanks for the help
    Mar 2003
    spazzkid: about sa pagtanggal ng bulbs, meron yan sa manual ng corlla mo.
    question lang ho. Sabi kasi ng friend ko gamit nya is raybrig sa hi-ace and lancer nya pero di na daw sya nag palit pa ng wirings and add relays.
    saka Philips vision plus na all weather pwde din daw yata di maglagay ng relays and palit wirings. by the way 90/100 wattage.
    Saka anyone knows where to buy and how much ang philips vision plus?
    ty.
    pwede di magkabit ng relay, pero iikli yung service life ng bulbs mo...
    you'll also notice a big difference in terms of lighting when you add a relay kit and use thicker wires.
    ssaloon, magkano aabutin palagay ng relay? saka san marecommend mo. thanks.
    pahabol, bayaw ko nagpalit ng PIAA bulbs 4 got wattage pero higher than stock sa CATS sa headlight 2.8 pajero, di na daw pinalitan wirings/relays. just replaced the stock bulbs, ok na daw accdg. to their elect. may 2 months na din nya ginagamit ok naman.
where to buy headlight bulb?
