Results 1 to 12 of 12
    Aug 2005
    Tsikot experts, patulong naman.
    Yung brake lamp at handbrake indicator ng auto ko (Honda Accord 96 AT), naka-on kahit umaandar ako on D4.
    possible na sensor problem lang ito pero ano kaya ang mga possible
    causes nito?
    also, saan pwede patignan ito? (I live in diliman, qc so sana within the area)
    thanks in advance...
    Aug 2005
    mods, 3x pala na-submit ung thread. pa-delete na lang po ng iba. sensya sa trouble. thanks.
    Best case scenario yung parang contact lang ang prob... do you feel any drag ba sa brakes? if not, baka nga electrical lang to or even yung contact lang.
    How about your brake fluid? If mababa na brake fluid mo that lights up din kasi po.
    Aug 2005
    thanks. ok naman ung brakes. not sure about the brake fluid, though.
    possible na un nga. thanks again.
    Baka un contact nga lang yun. Plastic daw screw nun tapos replace ng steel screw.
    most likely the brake fluid is low . . had the same problem. nagka leak in one of the copper tubes sa brake line ko.
    check the fluid asap. baka may leak ka. i'd rather not move than not stop ;)
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    Low brake fluid din ako when that happened.
    Kaya pala bumaba brake fluid dahil sobrang nipis na ng brake pads and the pistons were pushed all the way out na.
    Aug 2005
    thanks sa mga sagot.
    brought it to a shop tapos sabi, low brake fluid daw. kaso, nilagyan na namin ng brake fluid, nag-ilaw pa rin. possible na ung sensor lang. ibabalik ko pa sa shop for further check up.
    Pwedeng sensor. Yung sa Mercedes ko sensor din. Binunot ko na lang kasi regular ko naman chinecheck ang underhood fluids.
    check mo rin yung brakelights sa likod
    dati ganyan problema ko, (same ride tayo), pundi lang pala yung isang ilaw sa likod.
    Sep 2004
    Quote Originally Posted by boggart
    causes nito?
    Pre
    Had the same problem on my 1997 Accord VTi-S...simple lang yan, busted or pundido na yung bulb ng brakelight mo...just buy a pair of 12V brakelight bulbs, 10pesos each, SOLVED na problema mo...
    And to think I almost had my brake pads replaced at P600 each before, buti na lang I read the manual...
    Nov 2003
    either bulbs or fluid. in many cars equipped with abs, it's the abs light that lights up once the bulb is busted.
Brake lamp/Handbrake indicator problems
