Results 1 to 11 of 11
    AE92 Small Body - with upgraded(Way way back) wiring to accommodate 100/90w bulb. High lang ung gumagana, I tried changing bulbs (with other variant/brand) pero ganun parin, I even tried interchanging the headlight fuse (the two 10A) still no avail. What I noticed tho (even before) that when I turn on my Headlights (kahit low lang) my pumipitik sa fuse box and kanina ko lang nalaman na ung fuse ng horn ung pumipitik. What could be the reason of this problem? fuse or wiring?
    could be a stock up relay. kahit naka low ba switch mo, naka-high pa rin o hindi umiilaw ang low? what you can try is to use the original socket to isolate the problem.
    Quote Originally Posted by Ginnova View Post
    No sir, di talaga umiilaw, kasi kapag nag-high ako okay naman. parang pundido ung LOW function nya. wala na ung original socket neto.
  4. #4
    sa H4 socket kasi your LO is separate from you HI. Pag nasa LO ka, the ground and the +12v for the LO turns ON and pag HI, there is 12V across ground and HI while there 0v across ground and LO terminal. Sa case mo you can remove the HI wattage harness as suggested by Ginnova, buy new headlights sockets (go na for the ceramic type) coz there is a big chance sira na yung relay nung harness mo or all together meron problema sa connections nung harness.
    Quote Originally Posted by eatmylens View Post
    custom made ba o yung ready made warning harness ang install mo? H4 po ba?
    na-encounter ko rin yan. pag-install pa lang eh ayaw na gumana ng Low beam. the ready made H4 warning harness i bought had this small plastic box (1/2 size of matchstick box). tinanggal ko lang at jumper yung dalawang terminals going to the small plastic box at yun OK na.
    ang H4 ay minsan eh positve common or negative common. kaya kung hindi brand/model specific ang nabili mo na wiring harness ay may chance na hindi gumana lahat.
    HTH
    Salamat sa mga reply nyo. Feeling ko nga Socket, Magkano po ba ung Ceramic Socket? Eto lang ba ung kelangang bilhin/palitan?
    Di ko alam kung ano ung biniling socket or ano ung mga ginawa dun, sa kuya ko kasi tong car na to before and yep, H4 ung bulb.
    i think you can buy a ceramic socket for around 200-250 / pair.
    ____________________
    my 1st headlight retro
    That's all i need sir? wala ng iba pang papalitan?
    Problem Solved! Nalusaw lang pala ung isang Fuse(15a). My nakita kasi akong dalawang fuse na nasa labas nung fuse box. Di ko alam kung bakit meron dun at halatang sinadya lang to nung mekaniko na nag-upgrade ng wiring nung headlight. Pero nakabili na ako ng Ceramic Socket (189php *Ace hardware) bago ko to nalaman.
    Anung advantage/benefits ng Porcelain socket?
    Pwede ba na yung LO is naka bukas kapag ng HI beam ka?
    Jan 2008
    pwede din.. kaso aksayado lang.. yung ibang off road vehicles ganyan ang design. hindi namamatay yung LO pag nag HI ka..
Ayaw gumana ng LOW
