Results 71 to 80 of 106
- Mar 2011
- 9
September 3rd, 2014 11:52 PM #71standard is 55w but on some fog lights (like the one I have it's lower than that) if its aftermarket (like euro beam driving, spot or fog lamps) I'd (myslef knowing the risk involved of burning the harness, draining my battery if my alternator can't keep up with the lights+ hibeams+lowbeams+ac+wipers+2x100w bulbs idling in traffic) put on 100w off-road only bulbs.
- Jan 2014
- 38
September 11th, 2014 12:36 PM #72hi tatanong lang. 01 nissan grandeur auto ko running on 4 H1 headlights bosch all weather sa low. some korean brand pure yellow sa high stock wattage lahat. pansin ko di masyado pinapansin yung HI ko nakakainis minsan pag may makakasalubong ka na naka bright.
plano ko ipalinis headlight ko this weekend tapos upgrade na din ng wiring add relay and ceramic sockets. since plastic housing ko, advisable ba maglagay ng 100w sa hi beam? hindi naman madalas ginagamit high beam pambulag lang din sa mga naka HID at hibeam palagi.
- Aug 2012
- 2,767
September 21st, 2014 11:55 AM #73not recommended ang high wattage bulbs sa plastic lens. try mo magpalit ng H1 bulbs with any of these models:
Osram Night Breaker Plus = +90% more light on the road
Philips X-treme Vision = +100% more light on the road
Osram Night Breaker Unlimited = +110% more light on the road
- Jan 2014
- 38
September 22nd, 2014 05:35 PM #74Thank you sa reply sir. napalinis ko na headlight ko sa MBN car audio accesories sa short horn sa may congressional. In and out yung linis. ayos na ngayon di pa ako nagpapalit ng bulbs. Plano ko nga bumili din ng Philips x-treme vision. madami na akong nabasa na maganda nga daw talaga yun compared sa osram night breaker
Maraming salamat sa response sir! More power
- Jul 2012
- 329
September 25th, 2014 08:59 AM #75newbie question.
how long po usually life ng headlight bulbs? kasi i just recently replaced my stock headlights sa jazz 05 ko pero after a year pundi na agad yung low beam.. pero hi beam ok pa nmn. im using h4 60/55w 12v. ok lang po ba mag upgrade nko, instead stock sould i buy branded bulbs? do they last longer? obvusly they are not cheaper.. what spex should i look for? should i stay with 60/55w or higher? and if i do go with a higher spex should i change sumthing in the car? thanks po
September 25th, 2014 10:38 AM #76
depends on the bulb and electrical system.
the longest i had was a stock philips bulb.... used it for 6 years.
shortest one was around 5 months.... yung mga japanese bulbs na nabibili sa concorde.
for osram NB, the longest one i've used is 4 years...
sa HID, isang taon lang.
stick with the standard wattage or you will risk burning your reflectors and will make discolorations sa HL mismo.
if you would change to a higher speced bulb, you need to use a relay and a separate wiring.
September 25th, 2014 12:51 PM #77
My Dewitt Rally Gold all weather is now 8 years old. Still working fine.
- Jul 2012
- 329
September 25th, 2014 01:10 PM #78thanks for the reply.
im planning to buy a branded bulb and stick with 60/55w na lang. may available po ba na puti nun or stock color lang rin? how much po yung philips? kasi yung nakakbit sa oto ko generic lang ata.. yung mga made in japan
- Jul 2012
- 329
September 25th, 2014 01:17 PM #79in addition... may mga nakikita akong 3300k brighter and so on.. does this mean safe gumamit ng mas maliwanag na bulb as long as 60/55w ang specs?
September 25th, 2014 01:42 PM #80
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
