Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    Nov 2003
    Help!
    I was driving my trusty '95 Lancer EL yesterday morning. I signalled to turn left. All of a sudden, the left signal light started to blink very rapidly....twice as fast as it originally would. Parang taxi tuloy ang dating niya. It's been that way ever since.
    The right signal light didn't seem to have any problems. It would blink at the original frequency. When I put on my hazard light switch, both left and right signal lights would blink at the original frequency. So, it's just the left signal light that has gone haywire. When I switch the left signal light on, not only does it blink rapidly, but I also learned that the bulb for it in the rear would not light up.....only the left front would light up.
    I assume it is an electrical problem. But what could have happened? Is there any DIY solution to this? I haven't had the chance to check on the left rear signal light bulb to see if it has burned out, but assuming it has, could this be contributory to the problem?
    Quote Originally Posted by groucho
    Yes.
    Nov 2003
    mazda, hanep naman sa bilis ang sagot mo. Thanks. I'll check that out as soon as I have time.
    Any other ideas as to what happened?
    yes din...hehehe
    that means that you should turn left as fast as you can
    seriously...may napundi sa mga bulbs mo...
    usually physical appearance pa lang ng bulb alam mo na kung alin ang pundi...
    Diy na yan!!!
    Dec 2003
    super bilis lng yan palitan, 2 mins of ur time
    Apr 2005
    yung hindi umiilaw malamang pundido. tanggalin. kung maitim na, pundido na. dalhin sa auto shop, bumili ng kapareho. ikabit. ok na
    heto ang detailed DIY steps dyan:
    1. ilipat mo yung right rear signal bulb dun sa left front signal bulb.
    2. tapos yung galing dun sa left front signal bulb ilipat mo sa right front signal bulb
    3. tapos yung right front signal bulb ilipat mo sa left rear signal bulb
    4. lastly, bili ka ng bulb tapos ilagay mo sa right rear signal.
    HTH! :D
    Nov 2003
    Thanks for the input, guys. Will let you know what happens as soon as I attend to the problem.
    Quote Originally Posted by kimpOy
    hazard mo lang...tapos check mo kung alin ang di gumagana. ;)
    Quote Originally Posted by baiskee
    pssst! meron signal light bulbs na 2 ang filament, 1 for turn signaling and another for hazard signaling. so pwede sumindi yung bulb pag naka-hazard pero pundido na yung para sa turn signal.
    :lol:
    Pundi lang yan.
    May 2005
    Quote Originally Posted by yebo
    sir yebo..kung yun po ba sinasabi ninyo na 2 filament or double contact.
    ay pareho po ba ang liwanag niya ..kasi iyon double contact na gamit ko ay ..isang mahina at isang malakas?
    that's normally an indicator na sira yung bulb sa rear (left or right) pag faster ang blinking ng signal light (indicator) sa dash...nabago kasi yung current flow because of the open resistance created by the busted bulb...hth
    Dec 2003
    heheh
    paano pag minsan minsan lang sobrang bilis ang pag ilaw, at hindi lagi
    pag nababasa siguro, may open siguro sa electrical mo
  17. #17
    ung double contact is used mostly sa brake (21 or 32 watts)and park(5 watts) lights...ang signal and reverse ay single contact yan..21 watts mostly, ung iba 32w, pero mayroong 5w or 10w used for park lights.
    iba-iba shapes and sizes nyan, better to have the burned-out sample...
    may taiwan bulbs that are cheaper(less than 20 pesos) but dont last that long, japanese,geman bulbs last longer but at a hefty price... just use plain/white bulbs, so that others can see you easily, dont buy those taiwan colored bulbs, especially blue and red ones..they give out less light, make the other drivers hard too see it at night...for our safety,right?
    may LEDS din, pero mahal, ung white might not give good illumination when used as a reverse light...LEDS are good for signals and park lights..
    ung lite ace ko, double contact ung park light sa front (lower wattage used for park, higher wattage used as a corner light when i switch the signal on on either left or right)
    kalimitan lang naman bumibilis ang pag-flash ng signal light is when one of the major signal light bulb on either front or rear is busted..
    kaya for easier checking, turn your hazard, and walk around on your car...ung walang ilaw, sure pundido un..
    pero kapag napundi ulit pag-kakabit mo ng bago, pacheck mo na linya nyan, may dikit(grounded) ung linya..
    hope this helps..
  18. #18
    Quote Originally Posted by Mojo
    it would be an indicator that the bulb must be nearing its end...mapupundi na siya...
    hhhmmm... salamat po.
    May 2005
    sir yummy,,
    how much po ba ang mga LEDs?
    ano po ba different colors na maganda pwede gamitin ?
    any brand or country made na reliable ...para tumagal hirap kasi kung may back job
Signal Light Blinks Twice as Fast
