Results 1 to 10 of 74
    cree led, afaik, is 6000 kelvin so medyo alangan din ako maglagay ng cree led bulb sa headlights. meron binebenta na 30 watts cree h3 and h4 bulbs e. P1400 each, pwede na sana sa starex.
    Apr 2014
    6000k does not give good visibility DAW sa ulan so not advisable. But IDK if anyone has tried installing them. Cheaper pa kay HID.
    Posted via Tsikot Mobile App
    Quote Originally Posted by tevilo View Post
    Well, in a direct comparison of 6000K output with 4300K -- same type of bulb, same enclosure -- there's definitely better visibility in the rain with the 4300K because it's slightly more yellowish. Comparing the 6000K LED output vs OEM yellowish, and that's another story. With great output comes great glare as well, kaya si glenn manikis patay sindi sa LED niya.
    Jul 2006
    Is there such a thing as "yellow" LED's?
    With today's unpredictable weather, IMHO yellow(ish) coloured lamps is the way to go.
    Jun 2011
    meron yellow tint for LED BAR...
    Jan 2009
    The problem with using LED is purely in the optics. Nothing exists yet as an aftermarket product that can emulate the cut-off that is present in standard automotive low-beam headlamps. In that sense, it should be illegal to use LEDs, from a certain intensity, to be used as driving lights.
    LED DRLs by design are operated at relatively low-intensity. So even if they don't employ a cut-off, it is less likely to cause glare to oncoming drivers. Some cars even lower the intensity when you turn the headlamps. Although, I'm starting to see LED DRLs that blinding, day or night. These too, should be banned, IMO.
    Jan 2009
    LED DRLs by design are operated at relatively low-intensity. So even if they don't employ a cut-off, it is less likely to cause glare to oncoming drivers. Some cars even lower the intensity when you turn the headlamps on. Although, I'm starting to see LED DRLs that are blinding, day or night. These too, should be banned, IMO.
    Feb 2011
    kain ka yema. itabi mo yung balat pagtapos tapos dikit mo sa led bar
    anyway, you can easily tint it. If you want something that is not permanent, maybe you can look for a aftermarket cover or custom made acrylic cover, then ayun yung i-tint or painted with clear yellow paint.
    some LEDs have the option to install a snap on transparent yellow cover to give you the yellow effect.
    Sep 2013
    would it give off the same rain visibility as the real yellow 4300k bulbs? been thinking of doing the yellow tint stuff.
anyone using LED foglams?
