Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Good Day,
    Ano kaya ok sa tatlong Bulb na ito, Stock Halogen Bulb (100/90w), LED or HID? Planning to upgrade then lalagayan ko siya ng
    Yellow Film Tint Headlight? Para Battle of Old School vs to the new gen. Thanks in Advance.
    Quote Originally Posted by drich_enriquez View Post
    Good Day,
    Stock halogen bulbs are usually 55watt.
    Stick with higher intensity 55 watt (Osram Nighbreaker, Philips XtremePower) - you risk burning the socket and wiring with 95w (unless the stock halogens are really 95w)
    Kapag HID naman, if you are not going projectors, waste of money -- nakakasilaw yan sa ibang motorista.
    LED, not sure.
    Apr 2010
    Wag mo nang palagyan nang tint or i-paint yung plastic/glass kasi binabawasan nito ang usable light
    I have a pair of 100w H4s from Narva, mahigit 1 year na rin sa akin ok pa naman. Basta tama ang alignment di nakakasilaw sa kasalubong. Mas OK ito IMO kesa magpalagay ng cheap HIDs without projectors. Kailangan nga lang glass ang headlight housing mo and upgrade na rin ng headlight circuitry with upgraded wires, sockets, relays para maximize ang output.
    Aug 2010
    Good Day,
    stock wattage is 60/55w. if you upgrade to 100/90w make sure that you install relay and ceramic plug. pagawa mo sa car electrician. kung hindi, masusunog ang cable ng auto mo.
    pag plastic ang lens mo... better stick to stock 60/55w.
    no need to put yellow tint. instead buy osram all season or bosch all weather. yellowish ang bato niyan.
    re hid, basahin mo ang thread na to.
    HID problem on my reflector halogen..
    Quote Originally Posted by fireice2 View Post
    summarize ko lang kung tama pagkaintindi ko.
    Halogen bulb + reflector = ok
    HID Bulb + reflector = go kill yourself
    HID Bulb + retrofit = Go go go
    Thanks.
    if you cannot afford retrofitting for hid... halogen ka muna. ipon muna.
    Oct 2009
    nag HID ako dati pero sabog ang liwanag at mahirap din sa gabi lalo na kapag maulan..lagi pa akong tinataasan ng ilaw ng kasalubong ko.
    kaya binalik ko nalang ung orig na osram mas malayo ang bato ng liwanag at naka pantay ang liwanag..
    Ang lighting kasi ng mga HID tipong liwanag ng spark ng welding. Kaya masisilaw talaga mga kasulubong mo. Advantage para sa iyo, pero sa mga kasalubong hindi.
    Sent from my Starmobile UP+ using Tapatalk
    Thanks sa Info. Ask ko lang any news about LED Bulbs?
    Okay yan, mas maliwanag sa halogen, less power consumption at hindi umiinit nang husto vs stock bulba na halogen. Dami din nagbebenta sa Olx, just make sure to buy the high quality ones.
    Good Day,
    what's your car? sa akin kasi mas ok pa din ang stock na Osram NBs.
    if you are going to increase the wattage of your bulbs, baka mangitim yung reflectors and lens.
    Good Day,
    Quote Originally Posted by 1D4LV View Post
    Toyota Innova sir ID. Kung Halogen I'll Stick na lng sa 60/55w. I'll concentrate na lng sa LED ay HID.
  11. #11
    plug and play LEDs = waste of money.
    [QUOTE=garyq;2578194]plug and play LEDs = waste of money.[/QUO
    Hi. Sir Garyg ask ko lang, kapag magpapakabit ka ng LED Bulb, kailan ng Projector headlights? May Sariling shop po kayo?
    Sir Ry kailangan ba ng relay sa wiring? Or deretso saksak na sa plug?
    May plug and play na led hl. Yung iba naman may kunti lang na modification. Ask mo lang pagbibilhan mo if plug and play.
    Apr 2010
    Napundi yung low nung isang piraso ng Narva 100/90w after 1.5yrs, pinalit ko new pair same model din (Narva 48901). According sa isang site, 150hrs lang ang lifespan nito.
    Sa Ace bili ko dati 250/pc, sa auto supply 160/pc lang same markings
    Jun 2012
    May be you mean 1,500 hours. Kung everyday nakasindi ang ilaw mo for one hour, and its life is 150 hours, your lamp will only last for 150 days or about half year.
    May 2015
    Any inputs about alva led headlights?
    i've tried both philips extreme vision and osram NB. konti lang difference sa oem. the best pa din talaga sa akin ang raybrig. yung H7 na dalawa ko (on GS and sorento) 55w rated but 130w ang buga, more light, longer beam. you can also get it in many temps (3700k, 4400k, 5000k, 6000k). around P1600 per pair last na bili ko for the sorento when the hid ballast conked out. halos same color sila ng HID. na-compare ko kasi yung driver's side head light e naka hid pa din, passenger side head light hid lang ang pundido ang ballast. mas malayo pa ang buga kesa sa hid so i will probably just disconnect the hid on the driver's side when i get home next time and replace it with the other raybrig bulb.
    Kahit kaya sa H4 same din performance nang raybrig vs osram nb or pxv?
    di ko pa na-try h4 ng raybrig e. last month ibabalik ko sana to h4 yung bt50 headlights ko kaso iba na yung mount nung hid upgrade, d2r/s/c na yung mount. buti na lang di pa ko nakabili ng bulbs. wala din kasi ako makita na h4. puro h7, h11 and hb4 lang nakita ko so far. di ko lang alam sa banawe baka meron.
Upgrade Headlight- Halogen Headlight (100/90w), LED Bulb or HID
