Results 1 to 20 of 27
    Aug 2006
    nilagyan ko ng HID yung vtec ko 96' gusto ko sanang malaman kung pag tinangal yung [glare guard] sa loob ng headlight, kung ano ang difference. magiging sabog ba ang ilaw? or sobrang nakakasilaw? or ok lang na malakas?? 6000k by the way yung bulb phillips with hella ballast ignitor. has anyone done this kind of customizing in their vtec headlights if so please share some experience (what changed in the process) marami bang nagagalit so sobrang lakas ng ilaw??? thanks!!!
    ito nga pala yung picture, it may help (red arrow) glare guard
    In the first place, installing an hid kit to the non-projector headlamp of your civic is quite useless.
    Removing the glare guard will only complicate matters as it will BLIND incoming vehicles.
    pag inalis mo un magiging sabog ang ilaw mo mababaliwa ung hid mo at lahat ng kasalubong mo bubulagin mo!
    Aug 2006
    Quote Originally Posted by mazdamazda View Post
    I understand your point, but realistic in this situation there's 1 out of 5 modified vehicles has HID kit with out projectors (specifically in PI), which you are aware, it's obviously showned with your response, so therefore it is quite useful for some people even though their car isn't equipped with projector lenses. Don't forget this statement was meant for people who has done this project, and is equipped with HID. All you have to say is "will blind incoming vehicles" do you have HID yourself ? if not your reply is "quite useless" as well. thanks!
    ako naka hid ako sa sir ko but hinde ako naka projectors un lang i make sure na hinde glaring ung aim nung ilaw ko! pag tinangal mo ung cover mabwibwisit lang sayo ung mga kasalubong mo at baka batuhin ka pa!
    Oct 2004
    Weather help me now.
    Quote Originally Posted by si_dino_to View Post
    Hi. Maybe the ratio is 1 out of 5 or even less. But that doesn't mean its right. I guess only 1 out of the 5 actually did his reasearch before slapping on HID's. HID's were never meant to work in standard halogen lamp housings. Magiging ala chamba na iyan. IF it does, swerte na lang. If it doesn't, better do something about it. No one will lay down the law on you if you don't correct it. I just hope you do, for the sake of being courteous to other motorists.
    Napaaway na ko sa daan dahil sa mga motorists with blinding HID's. What were they thinking? Sila lang may karapatan na makita yung dinadaanan nila? Hindi ko naman sila binabato as previously posted by Mamar. But I do have a handheld halogen spotlamp between the front seats to even things up.
    BTTT,
    Removing the glare guard will only make matters worse. So don't.
    i'm ignorant about these things so i'd like to know why would it be useless to use hid bulbs on stock headlamps? pls enlighten me
    Because standard housings are unable to sharply focus the HID light. Which results not only in wasted light, but also p*ssed off motorists.
    Nabasa ko lang iyan sa ibang HID threads dito. Sorry, I'm not really interested in HID's. My headlamps are not compatible with them and baka maiyak lang ako when the ballasts go boom while I'm fording water.
    Aug 2005
    bili ka nlang projector type.
    magiging sabog lang un buga... wag mo na tangalin para kahit papanu may focus parin...
    Quote Originally Posted by baludoy
    so hid bulbs are primarily designed to be used hand-in-hand w/ projector type headlamps only?
    YES. Have you seen any car manufacturer slap in an HID to a halogen-type headlamp? None!
    That's because I researched first about HID kits before buying one. And since my vehicle is not equipped with a projector housing I didn't buy one to spare me from joining the you-have-to-buy-an-HID-kit-if-you-are-modifying bandwagon.
    Not as quite useless eh?
    Jun 2004
    Most likely sabog yung ilaw dahil nde projector yung headlamp, tapos pag tinanggal mo yung cover na yun daming masisilawan dyan, baka to the point na ikaw rin nde makikita dadaan mo dahil puro mga mag h-high beam katapat mo.
    Tapos dahil 6000k color temp, panget visibility during rains.
    in case dino missed the HID FAQ, here it is:
    http://tsikot.yehey.com/forums/showthread.php?t=20763
    and please, don't take off the glare cover, for the sake of motorists that you'll be coming across.
    Bawal mag-away. Healthy discussion lang.
    oo tama! mga matataba lang pwede magsalita!
    anyway, i was blinded by hid equipted crv kanina kakainis talaga..
    just install your hid properly..what might seem safe to you is totally opposite for the others..
    Quote Originally Posted by Hero View Post
    ibig sabihin pala hero i can talk all day! ngyahahahahahaha!!!
    with regards to your query, i suggest dont remove the glare guard. blinding and dangerous to oncoming motorists
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    thanks for the heads-up
    Oct 2004
    Huh????
    :fly:
    Apr 2006
    update naman sa thread starter???
    ano ng ginawa mo sa headlight mo?
96' vtec headlights [glare guard off] HID equipped
