Page 2 of 2 FirstFirst 12
Results 21 to 40 of 49
    15 minutes of idling without water in radiator
    any engine with any motor oil can do that
    Oct 2017
    Dapat nag request ka ng road Test, hinataw mo yun hillux
    I wish I did kaso office hours eh. hehe baka makita sa cctv.
    Quote Originally Posted by mcoy123 View Post
    Re radiator heat. . . D po sguro talaga iinit kasi wala naman dumadaloy na water galing sa makina
    But shouldn't the needle at least rise? Also, care to explain the exhaust manifold part? Why is it cool to the touch even if umaandar yung makina? One thing i noticed though, maingay ba talaga 1GD engine?
    Yes, but the needle didn't move past half.
    As much i want to believe na wonder lube does wonders, i stay away from something i do not fully understand. (*kaya siguro single ako) Pero kidding aside, i hope somebody can conduct lab tests para magkaalaman na once and for all.
    Aug 2017
    the temperature needle will not rise since the cooling system was drained there's no fluid in the cooling system where the temperature sensor is attached... not so sure about the exhaust manifold though...
    Sent from my F5321 using Tsikot Forums mobile app
    Oct 2009
    wala yan sa naimbento ng Lolo ko..kahit hindi lagyan ng gas aandar..
    patulak papunta sa gasoline station.
    Jan 2017
    The needle would not rise, it measures the h20 temp afaik
    Oct 2011
    Just recently saw this product on facebook marketplace again and it reminded me of a product I saw on home TV shopping before a couple of years back - works the same way as this I guess...
    X1R Corporation – Run With The Best – X1R Corporation
    NASA uses the product daw hehehe anyways was curious about this and looked for some reviews saw a couple but as someone previously mentioned on this thread there are no independent lab tests, and I think I also ran into an article about these before that oil additives don't really do much and since most motor oils already have additives in them. Me I personally use the Castrol Oil with Teflon tech additive.
    Sep 2012
    Pangalan pa lang you will wonder if it works.
    Pang kotse ba or pang lube ng ....
    Sent from my ASUS ZenFone 4 using Tapatalk
Wonder Lube - Pinoy Invention
