Results 21 to 30 of 85
September 28th, 2010 12:24 AM #21
No. Saudi Aramco has already divested out of Petron. Matagal na! Binenta nila sa isang British private equity firm. Pero binenta na din ata. I think Petron is now lead by Ramon Ang the same guy who runs San Miguel...
Tanungin natin si uls mas alam nya anong kwento ng Petron Corp...
- Sep 2010
- 92
September 28th, 2010 04:54 AM #22guys, i've tried both v-power diesel and petron turbo diesel.ive noticed noon pa na mas smooth ang andar ng engine ko with petron kht wla pa ung turbo diesel nla..b4 im using '02 xwind.dun plng noticed ko na na mas smooth ung idling with petron compared to shell.pati sa hatak smooth din xa.but im using shell engine oils..kso magaralgal engine ko pg shell diesel gamit ko..den now im using global dmax,gnun din na-noticed ko with regular diesel ng shell at petron.and then nung nlabas na ng petron ung turbo diesel nla,cnubukan ko.mas lumakas hatak at smoother lalo ung engine.d ako nhhrapan umarangkada with petron TD.ntry ko din v-power ng shell but same result as regular diesel nla,mgaralgal din sa engine ko..kht mas mhal ng 2-3 pesos ung petron TD kesa sa regular diesel e sulit nmn ako and i get better mileage with petron TD kht panay ang hataw ko sa slex..gnun din gamit ko oil sa dmax ko,im using shell semi-synthetic diesel oil.d ko lam kng bkt mas mlakas consumption ko with shell diesel unlyk with petron..ska d ko tlga kc gs2 idling ng engine ko pg shell diesel gamit ko.
- Sep 2010
- 92
September 28th, 2010 05:59 AM #23guys, i've tried both v-power diesel and petron turbo diesel.ive noticed noon pa na mas smooth ang andar ng engine ko with petron kht wla pa ung turbo diesel nla..b4 im using '02 xwind.dun plng noticed ko na na mas smooth ung idling with petron compared to shell.pati sa hatak smooth din xa.but im using shell engine oils..kso magaralgal engine ko pg shell diesel gamit ko..den now im using global dmax,gnun din na-noticed ko with regular diesel ng shell at petron.and then nung nlabas na ng petron ung turbo diesel nla,cnubukan ko.mas lumakas hatak at smoother lalo ung engine.d ako nhhrapan umarangkada with petron TD.ntry ko din v-power ng shell but same result as regular diesel nla,mgaralgal din sa engine ko..kht mas mhal ng 2-3 pesos ung petron TD kesa sa regular diesel e sulit nmn ako and i get better mileage with petron TD kht panay ang hataw ko sa slex..gnun din gamit ko oil sa dmax ko,im using shell semi-synthetic diesel oil.d ko lam kng bkt mas mlakas consumption ko with shell diesel unlyk with petron..ska d ko tlga kc gs2 idling ng engine ko pg shell diesel gamit ko.
September 28th, 2010 09:50 AM #24
[SIZE=4]Reminder: do not post messages in SMS/TXT shortcut format.
Read the rules.
Ignorance of the rules is not an excuse.
Repeated offenses will lead to banning.[/SIZE]
- Apr 2009
- 86
September 28th, 2010 03:32 PM #26
- Aug 2010
- 36
September 29th, 2010 03:30 PM #27alin ang best in terms of mileage/fuel consumption and cleaning power?
September 29th, 2010 07:53 PM #28
- Apr 2007
- 298
October 1st, 2010 12:06 AM #29I am using vpower diesel on my accent and i dont know if there is a significant difference using ordinary shell diesel. But when we try it on my dad's tucson, the engine sounds smoothly as well as there is improvement in acceleration.
October 1st, 2010 01:46 AM #30
Parang 1999 ata last year ng 4wd variant sa taiwan(LHD) so baka subic na yan narito saatin
Mitsubishi Philippines
