Results 1 to 10 of 20
- Mar 2005
- 97
June 15th, 2008 01:48 AM #1From: http://techon.nikkeibp.co.jp/english...080613/153276/
New Fuel Cell System 'Generates Electricity with Only Water, Air'
Prototyped vehicle
120W fuel cell system
Internal portion of the 120W fuel cell stack
300W generation system mounted in a luggage room (left)
Genepax Co Ltd explained the technologies used in its new fuel cell system "Water Energy System (WES)," which uses water as a fuel and does not emit CO2.
The system can generate power just by supplying water and air to the fuel and air electrodes, respectively, the company said at the press conference, which took place June 12, 2008, at the Osaka Assembly Hall.
The basic power generation mechanism of the new system is similar to that of a normal fuel cell, which uses hydrogen as a fuel. According to Genepax, the main feature of the new system is that it uses the company's membrane electrode assembly (MEA), which contains a material capable of breaking down water into hydrogen and oxygen through a chemical reaction.
Though the company did not reveal the details, it "succeeded in adopting a well-known process to produce hydrogen from water to the MEA," said Hirasawa Kiyoshi, the company's president. This process is allegedly similar to the mechanism that produces hydrogen by a reaction of metal hydride and water. But compared with the existing method, the new process is expected to produce hydrogen from water for longer time, the company said.
With the new process, the cell needs only water and air, eliminating the need for a hydrogen reformer and high-pressure hydrogen tank. Moreover, the MEA requires no special catalysts, and the required amount of rare metals such as platinum is almost the same as that of existing systems, Genepax said.
Unlike the direct methanol fuel cell (DMFC), which uses methanol as a fuel, the new system does not emit CO2. In addition, it is expected to have a longer life because catalyst degradation (poisoning) caused by CO does not occur on the fuel electrode side. As it has only been slightly more than a year since the company completed the prototype, it plans to collect more data on the product life.
At the conference, Genepax unveiled a fuel cell stack with a rated output of 120W and a fuel cell system with a rated output of 300W. In the demonstration, the 120W fuel cell stack was first supplied with water by using a dry-cell battery operated pump. After power was generated, it was operated as a passive system with the pump turned off.
This time, the voltage of the fuel cell stack was 25-30V. Because the stack is composed of 40 cells connected in series, it is expected that the output per cell is 3W or higher, the voltage is about 0.5-0.7V, and the current is about 6-7A. The power density is likely to be not less than 30mW/cm2 because the reaction area of the cell is 10 x 10 cm.
Meanwhile, the 300W fuel cell system is an active system, which supplies water and air with a pump. In the demonstration, Genepax powered the TV and the lighting equipment with a lead-acid battery charged by using the system. In addition, the 300W system was mounted in the luggage room of a compact electric vehicle "Reva" manufactured by Takeoka Mini Car Products Co Ltd, and the vehicle was actually driven by the system.
Genepax initially planned to develop a 500W system, but failed to procure the materials for MEA in time and ended up in making a 300W system.
For the future, the company intends to provide 1kw-class generation systems for use in electric vehicles and houses. Instead of driving electric vehicles with this system alone, the company expects to use it as a generator to charge the secondary battery used in electric vehicles.
Although the production cost is currently about ¥2,000,000 (US$18,522), it can be reduced to ¥500,000 or lower if Genepax succeeds in mass production. The company believes that its fuel cell system can compete with residential solar cell systems if the cost can be reduced to this level.
- Mar 2005
- 97
June 15th, 2008 03:24 PM #3
Mukhang Japan is making a move na. Saw this news on the internet just now.
TOKYO (Reuters Life!) - Tired of petrol prices rising daily at the pump? A Japanese company has invented an electric-powered, and environmentally friendly, car that it says runs solely on water.
[SIZE=-2]ADVERTISEMENT[/SIZE]
Genepax unveiled the car in the western city of Osaka on Thursday, saying that a liter (2.1 pints) of any kind of water -- rain, river or sea -- was all you needed to get the engine going for about an hour at a speed of 80 km (50 miles).
"The car will continue to run as long as you have a bottle of water to top up from time to time," Genepax CEO Kiyoshi Hirasawa told local broadcaster TV Tokyo.
"It does not require you to build up an infrastructure to recharge your batteries, which is usually the case for most electric cars," he added.
Once the water is poured into the tank at the back of the car, the a generator breaks it down and uses it to create electrical power, TV Tokyo said.
Whether the car makes it into showrooms remains to be seen. Genepax said it had just applied for a patent and is hoping to collaborate with Japanese auto manufacturers in the future.
Most big automakers, meanwhile, are working on fuel-cell cars that run on hydrogen and emit -- not consume -- water.
(Writing by Chika Osaka, editing by Miral Fahmy and Chang-Ran Kim)
June 15th, 2008 05:35 PM #4
Sir,
I'm sure galing pa rin kay Daniel Dingel ang theory of using water as a substitute for fuel.
June 15th, 2008 09:46 PM #5
Oh my I hope that's the real deal, dami pa namang genius dito sa forum.
Pinoys will always be pinoys...
June 16th, 2008 12:46 AM #6
sana nga totoo ito...
if ever this is true, highly doubt if this would be reality in the near future.
pwede rin nagpapajack up lang ng stocks yung company having this press release.
June 18th, 2008 09:32 PM #7
from http://www.treehugger.com/files/2008...-debunking.php
Genepax Water Car: Too Good to be True? Yeah
by Michael Graham Richard
How this Water Car Probably Works
"...It is actually possible to make a car look like it runs on water without breaking the first law of thermodynamics. The way it's usually done is with metal hydrides. These react with water to produce hydrogen, which is then used to power the car. But since these hydrides will deplete with time, they need to be replaced and so they are actually the fuel, not the water. And you can be sure that more energy will go into producing them than will be taken out, making them an energy carrier, just like a battery."
The Bottom Line on Water Cars
"As Carl Sagan used to say, extraordinary claims require extraordinary evidence..."
June 18th, 2008 10:11 PM #8
Fuel cell... Metal Hydrides... Research stage, not the real deal yet.
Man I can always google up "laws of thermodynamics" to defunct these claim, that's pretty easy.Last edited by CoDer; June 18th, 2008 at 10:18 PM.
- Jan 2008
- 4,726
June 18th, 2008 10:43 PM #9in this case WATER was used to produce ELECTRICITY to run the electric vehicle and NOT HYDROGEN used as a fuel in fuel fed engines
Choosing one would depend on your driving and parking conditions. Do you have your own garage =...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
