Results 1 to 4 of 4
Threaded View
May 11th, 2007 12:00 PM #1
In today's internal combustion engines, the pistons turn a crankshaft, which is linked to a camshaft that opens and closes the valves, directing the flow of air and exhaust into and out of the cylinders. The new method would eliminate the mechanism linking the crankshaft to the camshaft, providing an independent control system for the valves.
Because the valves' timing would no longer be restricted by the pistons' movement, they could be more finely tuned to allow more efficient combustion of diesel, gasoline and alternative fuels, such as ethanol and biodiesel, Shaver said.
The concept, known as variable valve actuation, would enable significant improvements in conventional gasoline and diesel engines used in cars and trucks and for applications such as generators, he said. The technique also enables the introduction of an advanced method called homogeneous charge compression ignition, or HCCI, which would allow the United States to drastically reduce its dependence on foreign oil and the production of harmful exhaust emissions.
The homogeneous charge compression ignition technique would make it possible to improve the efficiency of gasoline engines by 15 percent to 20 percent, making them as efficient as diesel engines while nearly eliminating smog-generating nitrogen oxides, Shaver said.
This improved combustion efficiency also would reduce emission of two other harmful gases contained in exhaust: global-warming carbon dioxide and unburned hydrocarbons. The method allows for the more precise control of the fuel-air mixture and combustion inside each cylinder, eliminating "fuel rich" pockets seen in conventional diesel engines, resulting in little or no emission of pollutants called particulates, a common environmental drawback of diesels.
The variable valve actuation system makes it possible to "reinduct," or reroute a portion of the exhaust back into the cylinders to improve combustion efficiency and reduce emissions. The system also makes it possible to alter the amount of compression in the cylinders of both conventional and HCCI engines and to adjust the mixing and combustion timing, allowing for more efficient combustion.
complete article at Science Daily
A relative of mine in Canada had his Scion FR-S PPF'd and then had it ceramic coated. He says it's...
Ceramic Coating vs PPF (Paint Protection Film)
