Results 1 to 4 of 4
June 27th, 2009 05:31 AM #1
Does anyone know if the LPG used in the Philippines is the same blend as the LPG used in homes. Some places primarily mix is propane and some that are primarily butane, and the more common, mixes including both propane (60%) and butane (40%).
Just curious for a project.
June 28th, 2009 12:37 PM #2
Does it matter? wouldn't the average octane be the same?
Propane injection ala devilsown? Going to bring LPG to the US market?
June 28th, 2009 09:03 PM #3
No, Plenty of propane injection companies around, Many people use or controllers and pressure switches for DIY kits, I've put plenty on vehicles in my day. Works well but you have to watch the EGT's.
I might put a kit on my personal vehicle there since it last for like a month or two of pretty hard driving. The tanks there are the only really questionable item. Plus I rather have it be more propane than butane since that's what I am use to working with. We can make LPG injection systems for vehicles there pretty easily. But like the news said there are millions of unsafe tanks so it makes it pretty risky unless you have a new tank and know the source.
Use with the water injection using 100% water can make some good power.
June 30th, 2009 11:55 AM #4
Not much I can tell you about the butane level. I can ask someone.
Tanks are safe. Greenfuel, which also partners with Ferman and the boys, sells toroidal replacement tanks (they fit in the spare tire well) for cheaper than other companies... but they're European... and safe.
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
