Results 21 to 40 of 162
Threaded View
    Feb 2005
    Hello Everyone,
    It's been a while since I made a post concerning my unbiased test of Khaos in California. In my last post, I indicated a 4% efficiency gain in mileage per gallon. It has been almost 3 months since I have Khaos installed in my 1991 Toyota MR2. I have been consistently getting 24-26 miles per gallon compared to 23-25 miles per gallon prior to the Khaos install. As I have indicated in my previous report, I have not recommended the Khaos yet due to the initial cost compared to the savings. I calculated that it would take approximately 18 months to recover the initial investment.
    I just went in and took my car to the California Required bi-annual threadmill smog test and it is sad to say the car failed.
    Let me know if you can access this test report (http://home.comcast.net/~pinay27/index.html), if not outlined below is the summary:
    TEST ==== RPM ========HC(PPM) ======= CO% ====== NO (PPM)
    = MAX = MEAS = MAX = MEAS = MAX = MEAS
    15 MPH ===1971 118 31 0.75 0.34 799 979
    25MPH === 2140 93 24 0.63 0.30 738 933
    Reading the other threads about Khaos, other tsikoteers made very wise assumptions and made warnings about increased NOX due to the lean mixture caused by KHAOS and possible future engine damage.
    Well, I immediately removed Khaos and got my car re-tested at the same shop and here is the second test without KHAOS.
    TEST RPM HC(PPM) CO% NO (PPM)
    MAX MEAS MAX MEAS MAX MEAS
    15 MPH 1919 118 43 0.75 0.31 799 835
    25MPH 2103 93 29 0.63 0.29 738 801
    Again, failed test due to high NOx but noticeable improvement of NO emmision. I took the car to a filipino mechanic here who, surprisingly has not heard of KHAOS, made a diagnosis and concluded that the catalytic converter is fouled up and needs to be replaced. Initial estimate to replace the "cat" is at a discounted $160.00.
    Wow, I only had Khaos in the Car for 3 months and it fouled up the catalytic converter that quick and would possibly cost me at least $160.00 to repair. Please note that I had the same car smogged 18 months prior and it passed with no problem.
    Here is the link to verify my recent tests. (Just copy and paste the following vin# jt2sw21n6m0006347) at: http://www.smogcheck.ca.gov/vehtests/pubtstqry.aspx
    Another link discussing NOx emmision repairs and causes:
    http://www.wivip.com/3_5_1.PDF
    I also scanned both test reports but it was too big (690 kb) to upload. I can email it to anyone including Mr. Planas or Freeman. Maybe ghost can give me his email address so he can somewhat post this test report.
    I initially read on the thread that Mr. Planas and inventionhaus is thinking of global marketing to include US. Fair warning lang po, siguradong ma-hahabla kayo dito for mis-representation, Pangalan lang misrepresented na (This is not a Turbo-Charger!) Guaranteed lawsuits if this Khaos device is marketed in the US that could amount to millions of dollars in penalty. Baka pati buong Pinas ma-bankrupt. I was really hoping for this device to work para naman may Filipinong sikat dito, pero nakakahiya ang mangyayari.
    So why am I doing this, kawawa naman yung mga kababayan natin diyan. I am hoping that I can prevent someone from being duped into getting khaos.
    So who is accountable, Planas, Inventionhaus, politicians the media or perhaps all? For making an unfounded endorsement of KHAOS? Don't you think someone has to be responsible enough to verify a product first prior to making an endorsement (Baka naman nakuha sa "Lagay" , uso pa ba yun dyan?).
    By the way I have not even touch on the effects to the environment of increased NOx, but that will make this thread too long.
    Cmon anyone in the media, I am challenging you to do the responsible thing and print my test report or you can do your own test and publish it. Apektado ang environment at ang ating mga kababayan.
Khaos - Emission Test Results, Conclusion....I hope!!
