Results 1 to 10 of 110
October 23rd, 2009 12:59 PM #1
Makakatulong ba ung pag lagay nang gear sa nuetral if malapit na sa stoplight? -- saw from some forums.
- Jan 2009
- 817
October 23rd, 2009 01:07 PM #2
October 23rd, 2009 01:15 PM #3
October 23rd, 2009 01:40 PM #4
+1 but plus handbrake
anticipate your next braking point to avoid over acceleration.
October 23rd, 2009 01:42 PM #5
huwag masyado magmadali sa daan... 5-10 minutes late lang naman ang diff. mo sa mga mabibilis magpatakbo pagdating sa pupuntahan... relax ka pa at dami nakikitang bebots hehehe
October 23rd, 2009 08:25 PM #6
Always keep it in D (Drive Mode) all the time... unless you are negotiating a steep gradient.
Dont use D when going uphills... put it in Low 2 or 1 if need be... this will lock you gears at the lower gear numbers and will be a much lighter load for your engine - meaning... lesser fuel consumption and lesser effort on the pedal.
Keeping it in D at uphill driving will force your engine to rev more and keeping the torque converter to work more also... of course it will shift automatically but the slightest pressure detected that can make your ECU decide to put it back to D will immediately put added unnecessary fuel into the cylinders.
With an AT tranny - you cannot Hypermile... dont put it in Neutral when you are already in high speed... this will shorten the life of your AT tranny. The only time you need to put it in Neutral is when you are stopping temporarily in traffic.
Also dont rev hard and make your tyres screem by putting the shifter immediately to drive. If you like to hear some tyres screeming... put it in drive mode first before you step on the gas pedal gradually but heavily. Never the other way around if you want your tranny to live longer.
Basically... a light foot will always save fuel.
October 23rd, 2009 08:41 PM #7
Tamang acceleration para sa normal driving at Weight reduction .Tagalin lahat ng mga mabibigat na bagay na hindi kailangan sa sasakyan .
October 30th, 2009 01:16 AM #8
UNLOAD. Yup, all the junk in the trunk does eat fuel. You can always bring a tire repair kit which is lighter than a spare tire and if you only do short distances this will do.
RELAX. Drop the ego. Drive in a relaxed manner and keep the foot off the gas pedal. No need to be a snail but do keep a consistent and safe speed.
N+Hand Brake when stopping. Not only will you consume less fuel, your brakes will last longer. Your hand brake will wear faster though.
Use energy efficient tires. Check Michellin. Others also have similar tires. And keep these properly inflated.
Keep the car in tip top shape. Clean air filter, flush ATF once a year (some do it every three months!) and check your power steering for leaks and fluid. Also remember to have your car properly aligned (lalo na pag luma na yung oto).
- Jun 2007
- 135
July 30th, 2010 09:56 AM #9* ehnriko
Just an inquiry sir. I read my 2005 Altis' manual and it said that don't put the transmission into 2 and L for a long time when negotiating an uphill as it will put uncessarry stress to the transmission causing it to get damaged. Well I understand 1-2mins of going uphill is not a long time.
But what about the Talisay going-up Tagaytay route. WOW thats more or less 10mins estimate (10mins that is if there is not line of cars going uphill) of very steep zig-zag uphill road.
I passed that route sometime this summer and BOY did my Altis 1.6E felt the challenge. There were 3 of us, me my wife and her sister. There was a car in front of me which was slow so I somehow lost momentum on certain areas...bad trip nga.
So what would be the proper way of attacking a steep uphill like the Talisay to Tagaytay route? Do we need to go L and 2 all the way? Do we have to turn-off the Over Drive also while in L and 2?
July 30th, 2010 10:03 AM #10
^^^ My suggestion is just to turn off the "Overdrive" in regular D mode....There should be no issue in your climb..... I am very familiar with the Talisay to Tagaytay climb, bro. It is a great driving 'experience', especially since I am driving a van..... (Did you buy some tawilis and maliputo from the vendors near Taal Lake?).....
10.4K:shazam:
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
