has anyone tried PETRON ULTRON RALLYE 10W40??
mukhang panglaban ito sa havoline energy...
any idea how much??
any idea how much??
Kaka-change oil ko lang using this oil. OK naman sya, comparable sa shell and mobil semi synth. 200/L sa Petron Morato/Timog
Havoline Energy's viscosity is 5w-30
Havoline Fully Synthetic's viscosity is 5w-40
Havoline Formula's viscosity is 20w-50
mga sir, ano po API rating ng PETRON ULTRON RALLYE 10w-40?
alam ko API SL na rin...
chieffy, magkano na yun bagong havoline energy na may synthetic na label? API SL na sya di ba?
thx:D
thanks sir pdc2for the info...seems like another good product
havoline energy synthetic has an API-SL rating...magkano? di ko pa alam selling price...di pa po ako nag-oorder sa Pandacanbasta tsikoteers may discount palagi
on viscosity ... since mainit sa pinas, dapat po ba na mas mataas yung rating? (i.e. better kung 5-40W kesa 5-30W)
chieffy ... can you PM me the price of your california dusters. thanks. :mrgreen:
when u SAY good product... ibig sabihin me fuel savings ka rin tulad ng hav energy?
200 per liter?? di 800 pr gallon?? sa gas station pa ...
mukha mas mura a. ma try nga next change oil
guys, i read somewhere na mayroon daw na Ultron semi-synthetic na P150 lang per liter. do you have any idea kung saan may ganitong prices?
got this from the petron site:
REV-X HD
DAY TO DAY DRIVING
Heavy-duty, single-grade diesel engine oil recommended for use in engines operating under mild to moderate service conditions.
- Provides engine protection against wear and piston deposits
- Gives enhanced engine performance at an economical price
APPLICATIONS
- AUVs & Vans
- Owner Jeeps / PUJs
REV-X HAULER
LONG DISTANCE DRIVING
Extra heavy-duty, single-grade engine oil formulated for all diesel engines that do not require multi-grade oils.
- Maintains engine cleanliness by reducing piston deposits and minimizing bearing corrosion
- Gives better protection against normal wear and tear
- Enhances engine performance
APPLICATIONS
- SUVs (4x4 / 4x2)
- Small & Mid Size Pickups
- AUVs and Vans
- Trucks & Buses
- Heavy Equipment
REV-X TREKKER
HIGH ENDURANCE
Premium heavy-duty, multi-grade engine oil designed to pass even the demanding requirements of modern diesel engines of American, European, and Japanes one-and-off road vehicles
- Extends oil drain capability longer than regular diesel oils
- Excellent anti-oxidation performance and superior soot control ensures oil provides protection to engine for a longer period
- Gives excellent wear, sludge and varnish control and shear stability that promote piston cleanliness and engine protection
- Outstanding protection against non-ferrous corrosion
APPLICATIONS
- SUVs (4x4 / 4x2)
- Large Size Pickups
- AUVs & Vans
- Trucks & Buses
- Heavy Equipment
REV-X ALL TERRAIN
4x4 POWER
Fully synthetic, heavy-duty multi-grade diesel engine oil that is designed specifically to withstand the punishment and stress on the engine caused by four wheeling, towing and hauling.
- Helps extend engine life by providing:
> Excellent control of soot-induced wear, as well as ring and liner wear
> Unparalleled anti-oxidant protection that keeps oil clean
> Outstanding piston cleanliness
- Provides outstanding shear stability so oil does not lose pressure over time
- Improves fuel economy, as well as extends oil drain interval, leading to lower operator costs and less down time service
- Substantial reduction in oil consumption
APPLICATIONS
- SUVs (4x4 / 4x2)
ULTRON EXTRA
DAY TO DAY DRIVING
Multi-grade engine oil recommended for use in engines operating under moderate service conditions.
- Enhanced engine cleaning and conditioning action
- Effectively controls wear and deposits
APPLICATIONS
- Small & Mid Size Sedans
- AUVs & Vans
ULTRON TOURING
PREMIUM PERFORMANCE
Multi-grade engine oil formulated to meet the high performance needs of most modern American, European and Japanese vehicles. It is also suitable for engines fitted with turbochargers or those operated under severe conditions.
- Gives better anti-oxidancy and anti-corrosion that lead to:
> Cleaner engine parts
> Better engine protection
> Longer oil life
- Provides improved high temperature deposit control that delivers:
> Optimum turbocharger performance
> Piston ring cleanliness
> Longer engine life
- Superior valve train wear protection that ensures combustion efficiency
- Prevents low temperature deposits with its improved sludge and varnish control
APPLICATIONS
- High Performance Sports Cars
- SUVs (4x4 / 4x2)
- AUVs & Vans
ULTRON RALLYE
HIGH ENDURANCE
Synthetic blend, multi-grade engine oil that combines the benefits of both fully synthetic and mineral-based oils. It is also suitable for high performance engines, especially those fitted with turbochargers, or those operated under most sever conditions.
- Gives all the benefits of multi-grade engine oils and more!
- Cleans engine parts better with its improved anti-oxidancy and anti-corrosion formula
- Gives longer oil life and extended drain interval
- Lets engines consume oil lesser than regular mineral oils
- Controls emissions better due to improved catalyst durability
- Allows easier start-ups in cold weather
APPLICATIONS
- Luxury sedans
- SUVs (4s4/4x2)
ULTRON RACE
EXTREME DRIVING CONDITIONS
Fully synthetic, multi-grade engine oil designed to provide maximum engine protection for all types of gasoline-powered vehicles. It is highly recommended for high performance, turbocharged engines.
- Provides outstanding thermal stability and oxidation resistance that allows:
> Longer oil drain interval than mineral and synthetic blend oils
> Extended oil life
- Excellent low and high temperature deposit control and anti-corrosion that lead to:
> Improved turbocharger performance
> Low sludge and varnish formation
- Gives better fuel economy than mineral and synthetic blend oils
- Extends catlyst durability to control emissions better
- Instantaneous start-ups in cold weather
APPLICATIONS
- Luxury Sedans
- SUVs (4x4/4x2)
just change oil ysterday. wla me mabili ng ultron rallye. just bought hav energy kina glenster *920/galon.
nxt time ko na lang subok yung petron rallye.
Is Havoline Energy with 5W-30 fit for the Philippine climate use? Im planning to use this to my Altis when its time to have a change oil.
I would recommend 5w-30 Amsoil full synthetic. That's what I've been using and some of my buddies that are heavy into track events w/ the Porsches.
The bulk of the engine wear happens when you start it. The quicker the oil can go from the bottom to the top and around the moving parts the better.
Amsoil preforms better than Mobil 1 against breakdown at high temps thats why it's more expensive but then again, oil is cheaper that having your engine rebuilt.
For older engines I would use a thicker viscosity for the reason that the clearances are not as tight as the newer engines.
Is Amsoil available in RP?
been looking around the net for its availability here in the phils, mukhang wala.
lahat daw ng test by independent labs shows this is the world's best oil. tiklop daw ang mobil sa quality nila.
when they put the word "first in synthetics" sa bottle nila, all lubricants companies in the u.s were given 90 days by the trademark officials to contest it, wala raw umangal, considering that lubricant companies are taking each other to court on various claims. mobil for one sued castrol.
alam daw ng mga mga oil companies na quality wise, amsoil is very good.
http://bestsyntheticoil.com/
http://www.amsoil.com/
how much po ultron rallye per gallon???meron po ba malapit sa mandaluyong???
