Results 1 to 10 of 81
August 20th, 2004 02:58 AM #1
i'm planning to get a new ride.. here are my top 4 choices; REVO SR, REVO VX200, CROSSWIND XUV, CROSSWIND XUVi..(although i'm a little biased in favor of the revo kasi subok ko na at hindi pa ako itinirik kahit minsan).
my main thing is a daily commute to/from work and to haul stocks from manila at least once a week. my average mileage is around 350 kms/week (200kms highway and 150kms city driving). at present, i'm using a 2.0L Revo SRJ A/T which is costing me an average of p1,100 a week in gas bills. Given the same situation, which do you think is a much better ride to get in terms of durability, maintenance and cost-effectiveness .. what are the pros and cons? which is the most beneficial in the long run ???
1. GAS or DIESEL
2. MANUAL or AUTOMATIC
3. REVO or CROSSWIND (if diesel)
HELP ME OUT HERE GUYS...Last edited by Elroi; May 20th, 2005 at 11:50 PM.
August 20th, 2004 03:07 AM #3
wala akong alam sa ganyan. pero sa diesel ako. ambilis tumaas ng gas ngayon e.
August 20th, 2004 03:15 AM #4
AUV lang ang kaya ko guys... di ba mas mahal ang maintenance ng diesel so it cost much more to maintain (including gas,oil change,etc..) say in a span of 6 months.
August 20th, 2004 11:01 AM #5
whether toyota or isuzu kunin mo... based sa needs and mileage mo.. i'd say go diesel. the maintenance is not that expensive. oil and filters lang naman ang ang maintenance ng diesel.
as for mileage figures, I can attest to the mileage of the isuzu 4ja1 engine... 11-12 km/liter combined city and highway driving. tested and proven over 85,000 kms and going.
pros and cons ng diesel vs. gas : punta ka na lang sa dieselclub.org forum...meron na ganitong thread :D just look for it ;)
hth
August 20th, 2004 11:06 AM #6
Diesel AUV M/T the best especially sa case mo. mahal ang maintennance ng diesel????? i don't think so kasi parehas lang naman ang oil change frequency (every 3000 kms) for gas and diesel(will depend din sa oil brand you use at kung paano mo gagamitin ang ride mo). Mas mahal nga lang ang pyesa ng diesel engine pero when it comes to toughness mas matibay ang diesel engines. In the long run you will appreciate your diesel ride especially tumataas na ng husto ang gas prices at saka take this example......... wala pa tayong nakikitang sarao jeepney na gas fed engine ang gamit......... why???.......... dahil masisira na ang kaha ng sasakyan mo ang diesel engine mo buhay pa...........pero syempre nasa pangangalaga talaga yan.
August 20th, 2004 12:20 PM #7
well, there are more factors to consider in this particular case:
1. since you will be using the vehicle on the highway a lot, you'll have to consider that a diesel produces more noise and more vibration, and is less responsive than a gas engine (for example, when you need to pass someone on a two-lane). in this case, a gas engine will give you more comfort which may be important to you.
2. a diesel will give you great economy in the city, but on the highway, the gas engine won't be very far off. since you'll be on the highway a lot, fuel economy won't be that shabby on the gas engine.
August 20th, 2004 12:37 PM #8
Tech: Gas vs. Diesel
Which is best for you?
By Chuck Schifsky
Photography by Steve Austin
Truck Trend, October 2002
Light-truck diesel engines of five to 10 years ago weren't so good. They were noisy, vibrated, had smelly exhaust emissions, and were more costly to build than their gasoline-burning counterparts. Today's diesels are much more civilized, but are they any better than their gasoline cousins? This is one of the questions we're asked most frequently regarding 3⁄4- and 1-ton pickups. To answer this, you must understand the positive and negative attributes of each engine, while considering what you'll use the vehicle for. Let's look at the important criteria you should use before making a final decision.
Before we start, it's important to note there are currently no 1⁄2-ton pickups available with diesel engines, even though there are some small "baby" diesels under development for use in 1⁄2-tons and midsize SUVs. This story concentrates on 3⁄4- and 1-ton trucks, but the concepts will be equal once the next generation of smaller diesels arrives.
Power/Torque
Advantage: Split Decision
Typically, gas engines make more horsepower, while diesels produce more torque. Are you looking for off-the-line acceleration of an unloaded truck? Maybe you use your truck around town where quick starts are important and you don't often tow a trailer or haul a load. If this is the case, then you'll want a gas engine. By design, gas engines rev faster and are able to reach higher rpm peaks than diesels. This allows them to attain greater horsepower numbers and quicker 0-60-mph times.
However, if towing capacity and brute pulling force are your game, a diesel is for you. The torque advantage of diesels is perfectly suited for pulling heavy loads up steep grades. Because of the relatively high-compression ratio necessary to ignite the diesel fuel (17:1 diesel versus 9:1 gas), a diesel makes all its torque and power low in the rev range. As an example, the GM 8.1L gasoline V-8 in Chevrolet and GMC pickups puts out 340 hp and 455 lb-ft of torque, while GM's 6.6L V-8 turbodiesel makes slightly less hp at only 300, but makes up for it in torque with a healthy 520 lb-ft of grunt.
Fuel Economy
Advantage: Diesel
Diesel fuel has a higher energy density than gasoline. One gallon of diesel contains approximately 147,000 BTUs of energy, while a gallon of gasoline only has 125,000 BTUs. This means it takes more gasoline to equal the power output of diesel, making diesel engines more efficient per gallon of fuel burned. Also, because diesel engines use the more efficient direct fuel-injection method (fuel injected directly into cylinder) compared to the port fuel-injection setup in gas engines where gas is mixed with incoming air in the intake manifold, the diesel system has little wasted or unburned fuel. Diesels also use about one third as much fuel at idle as gasoline units. Even though there are no official EPA-mileage figures for 3⁄4-ton and bigger trucks, we've seen diesels get six to eight more mpg than similar-weight gas pickups. Over the life of the truck, this advantage could be significant, especially if you drive a lot of miles.
Initial Cost
Advantage: Gasoline
Because of the high-compression ratios and resulting high cylinder pressure in diesel engines, they must be built to withstand more punishment than gas engines. Beefed-up parts include a thicker block and cylinder heads and stronger connecting rods, pistons, crankshaft, and valves. These parts can be costly. As an example, if you want to upgrade an '02 F-250 from the standard 5.4L V-8 to the 7.3L turbodiesel V-8, you're going to spend around $4800. However, to go from the 5.4L to the 6.8L V-10 gasoline engine, the price is a more manageable $600. Another diesel disadvantage that comes as a byproduct of needing heavy-duty components is increased weight. A diesel engine can weigh several hundred pounds more than a comparable gas model.
Noise/Vibration
Advantage: Gasoline
Despite huge improvements in noise isolation and engine-noise technology in pickup trucks in the past 10 years, diesels are still louder and shake more than their gasoline brothers. However, a recent back-to-back drive in two Ford trucks, one equipped with a 5.4L gas V-8 and the other fitted with a 7.3L diesel V-8, demonstrated that diesels aren't that far behind. At idle, the clatter and shake of the diesel are clearly noticeable, while it's tough to tell if the gas engine is even running. Under low-speed acceleration, the diesel still makes more noise. But once you're up to speed, there's little difference between the two even when accelerating on the highway.
Cold Weather
Advantage: Gasoline
Anyone who's tried to start a diesel engine on a cold winter morning knows the winner in this category. Diesels don't have spark plugs like gasoline engines do. The fuel is ignited spontaneously once it's injected into the cylinder that's already under pressure. When it's cold (below 30°), the air isn't hot enough to ignite the diesel fuel. To help counter this, today's diesel pickup-truck engines use a computer that senses cylinder temperature and injects the fuel later in the engine rotation. By injecting the fuel when the piston is closer to top dead center, the cylinder is under more pressure and the air inside is hotter, which aids combustion. As an added measure, most modern diesels come equipped with a 110-volt heating element designed to keep the engine block warm when the truck is parked.
Exhaust Smell/Emissions
Advantage: Gasoline
Despite petroleum companies best efforts at producing diesel fuel with lower sulfur levels, burned diesel fuel still smells much worse than burned gasoline. Beyond the smelly tailpipe, diesel lags behind gasoline in the areas of oxides of nitrogen (NOx) and particulate matter emissions. It's the particulate matter that causes the black soot seen emanating from diesel-vehicle tailpipes, while NOx is one of the components of smog. The next generation of diesel fuel is generally thought to improve on this situation.
Short-Term Maintenance
Advantage: Gasoline
Regular maintenance on a diesel is more costly, thanks to several items including the larger volume of oil in the engine and the fact that fuel filters and water separators must be serviced more often. Modern gas engines have an even bigger advantage thanks to extended service intervals on spark plugs, engine oil, and antifreeze.
Long-Term Maintenance and Durability
Advantage: Diesel
The flip side of a diesel-engine's expensive initial cost is its excellent durability. Dodge, Ford, and GM learned long ago they were better off buying diesel technology from experts such as Cummins, International, and Isuzu than spending tons of money developing it themselves. These manufacturers all have years of experience building heavy-duty, over-the-road diesels that have to log 100,000 miles a year for years on end, routinely haul heavy loads and may have to idle for days at a time. Think of the diesel engines found in GM, Ford, and Dodge pickups and SUVs as mini big-rig engines. The average gas engine is good for only around 125,000 miles before needing a rebuild and isn't designed to constantly pull a heavy load. A diesel can go more than three times this amount before needing an overhaul.
Fuel Cost
Advantage: Diesel
Because diesel fuel is easier to refine, taking less time to get from raw petroleum to final product than gasoline, it's usually priced lower than gas. However, occasionally in the U.S., diesel is priced the same or more than regular unleaded gas. This is often because diesel isn't as desirable in some areas leading to higher diesel prices. However, diesel advocates say that if more people drove diesel light trucks and cars, the price would drop dramatically in these areas—and possibly throughout the country.
Fuel Availability
Advantage: Gasoline
The lack of fuel availability is the reason we hear most often why people don't choose a diesel engine. Only about two percent of the nation's cars are diesel powered, compared with 25 percent for European countries such as France and Italy. The number is larger for light trucks and SUVs in the U.S., but the overwhelming majority are gasoline-powered. It's a chicken or the egg scenario. The car manufacturers say they'll build more diesels if people will buy them. Consumers say they'd consider diesels if there were more diesel fuel stations. Fuel companies, in turn, say they'd produce more diesel if consumers wanted it. Diesel pumps are easy to spot (they're the one's with the green handles) and can be found in most areas that have a large amount of commercial truck traffic.
Conclusion
Choosing between a gas or diesel engine comes down to what you'll do with the truck and where you live. If you use your truck like a car, desire quick, quiet acceleration, rarely haul a heavy load, and you don't plan on keeping it past 100,000 miles, you may want to consider a gas engine. They run smoother, fuel is easier to find, and they're easier to start in cold weather. However, if you use your truck for towing, value good fuel economy, and plan on racking up loads of miles, diesel is for you. In the end, the leading disappointment regarding diesels is that the price to add a diesel to a 3⁄4- or 1-ton pickup is still quite high versus a more powerful gas engine. But you'll make this back in fuel savings over time. On the flip side, we were pleased to find that manufacturers continue to develop diesel technology, especially in the areas of cold starting, combustion smoothness, and emissions. Now we need diesels in 1⁄2-ton pickups and midsize SUVs.
one of the articles I read when choosing between gas or diesel (madami pa, but i can't find them at the moment). i ended up going with diesel, and so far have no regrets.
August 21st, 2004 03:58 AM #9
it seems almost everyone is going for the diesel...
would i go for it too ?Last edited by Elroi; May 20th, 2005 at 11:51 PM.
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
