View Poll Results: TOP IT OR AUTO-CLICK IT?
- Voters
- 23. You may not vote on this poll
TOP IT
4 17.39% -
AUTO-CLICK IT
19 82.61%
Results 11 to 19 of 19
April 21st, 2008 12:30 PM #11
parati automatic.. and nagpapa-gas lang ako either early morning or late night.
everytime i fill-up, i record the distance travelled and the gas consumed to monitor my FC then reset the trip meter..
April 21st, 2008 12:43 PM #12
For me, automatic only.
However, everytime I fill up my tank, the gasoline attendant would always ask me if automatic or to the brim? Isn't it the gasoline station is exposing itself and us motorists, to some level of danger if they're filling a tank with the pump nozzle's mouth almost exposed? Maybe it's just me and no accident has happened,- so......just thinking aloud here, folks...
5808:bee:
April 21st, 2008 12:49 PM #13
Sagad. Mga 2-3 inches from the tip. Walang pagbabago yan dahil palagi rin akong bumababa at nakabantay everytime I fill up. as long as walang tapon walang problema…tsaka ko sinusukat ang aking FC….hehehe
April 21st, 2008 01:17 PM #14
normally, i just round it off the nearest hundred after clicking.
for example, if the auto click stopped at 1,250, i just tell the gas boy to fill it up to 1,300.
- Jun 2005
- 462
April 21st, 2008 08:25 PM #17Depends where my destination will be. When going long distance, I have it filled topped up but when it's city driving, its Auto click
April 22nd, 2008 06:17 AM #18
Ang mahirap kasi dyan is the fuel nozzles pump gas so fast that it bubbles/foams. This will yield you less than the desired amount of gas you paid for.
When I top off I sometimes pump in a bit more for my diesel, because I can see the filler neck and how full it really is. On the gasser I don't, since there's a flap that covers the inlet.
Most of the time I just go for the click, and then pour in the residual fuel left in the nozzle spout. Gasoline will just evaporate when you leave it in the pump after you're done so might as well pour that in, since you paid for it. Sometimes it's more than just a few drops. Actually, the main reason I do this is to prevent the fuel from spilling on my fender
April 23rd, 2008 10:36 AM #19
Auto click all the time.
Fuel leaks out of the spout as you drive off when you top up the gas or fill it up to the brim... sayang.
high idle RPM at engine start
