Page 2 of 5 FirstFirst 12345 LastLast
Results 21 to 40 of 86
    Dec 2003
    #21
    maglalaho to na parang bula
    Aug 2003
    #22
    just read this in the news today. ok na sana pero fly in the ointment pa rin yung KSTC! hehehe!
    Fuel savers by Pinoy inventors
    GOTCHA By Jarius Bondoc
    The Philippine Star 04/01/2005
    Oil and water don’t mix, conventional wisdom tells us. Experience adds that fuel contaminated with water conks out car engines. But with fuel costs rising every week and no end in sight, engineers are taking a second look at old knowledge – and debunking it. Motorists too are searching for the ultimate fuel saver. Fortunately for them, two Filipino inventors have blazed trails since 30 years back on simple technologies that cut not only fuel consumption by half, but also emissions down to almost zero. * * *
    One is water-in-diesel. Rudy Lantano has found that, with additive, water can blend with diesel for better combustion, hence less fuel use and pollution. More than that, it improves thermal efficiency, and thus powers up the vehicle for a faster ride with heavier load.
    Here’s how Lantano’s blend works. With a little over a part of water to nine parts of diesel, fuel is atomized into finer spray. Larger surface area is then exposed to combustion. Water inside the diesel droplets explodes at high temperature, thereby dispersing fuel even more inside the combustion chamber for further burning efficiency. In the process, exploding droplets break down and disintegrate unburned carbon deposits. The result: cleaner chamber, lower emissions, finer lubricating oil, less need for engine octane or cetane.
    Many thought Lantano crazy for coming out with his theory in the late ’70s. Undaunted, he experimented with additives to mix water with oil, using local wares like alcogas from sugarcane and biodiesel from coconut. Persistence paid off in 1996 when he won the World Intellectual Property Organization gold medal for outstanding invention. His additive is called Reloaded diesel, RL for short.
    Last February engineers pulled over for tests a Toyota Tamaraw FX (license plate DWR 970) and a jeepney (PYT 417) with a Japanese surplus motor. The vehicles were chosen for the thick smoke from their tail pipes. RL was poured into the fuel tanks. Instantly the FX’s emission dropped to 80 percent; the jeepney’s, 53 percent.
    Shell-Australia tinkered with its own mix and came up in 2003 with Aquadiesel: 85 percent diesel, 13 percent water, and 2 percent proprietary additive. Chevron and British Petroleum have picked up the idea. The International Energy Agency hailed the new fuel as a breakthrough saver for diesel vehicles that stop frequently and thus burn more fuel and emit more fumes, like buses and garbage trucks. But Lantano, who has been recognized by the Dept. of Science and Technology for 20 years, beat the big boys to it hands down. * * *
    The other fuel saver is a four-inch metal gadget that flushes the right amount of air with gasoline in engines. Invented also in the ’70s by Pablo Planas, the air mixer reduces fuel consumption by 15-50 percent, although some users rave about savings of up to 80 percent. It also brings down toxic carbon monoxide emission to almost zero, better than the 4.5 percent ceiling set by the 1998 Clean Air Act.
    Called Khaos Super Turbo Charger, it is mounted under the hood, fitted with a rubber hose to the intake manifold. The charger sucks in air and mixes it with gasoline inside the engine. The mix is what engineers have known for a hundred years for efficient gas burning: 15 parts air with one part fuel. With that mix, fuel burns efficiently whether idling or at high speed. Any pollution is the result of waste. But with gasoline thoroughly burned and used, engine emission drastically is reduced. This again makes for more engine power and, consequently, less repair and maintenance.
    An auto mechanic and jeepney operator in the ’70s, when most such refurbished MacArthur-type jeeps ran on gasoline, Planas wondered why he smelled fuel while warming up the engines every morning. He inserted a garden hose into the tail pipe and, revving up the engine, noted that the odor becomes stronger at idle. Planas read up on automotives and came upon the long-known 15:1 air-fuel ratio. He then fabricated a gadget that gave such an exact mix.
    Planas’s first chargers were crude. But he sold or gave away 500 of them to friends up to 2003. That year Planas met a financier crazy enough like him to venture into full-blast manufacturing. Soon Quezon City Mayor Sonny Belmonte met him and ordered all of city hall’s gasoline cars fitted with Khaos (named after the Greek goddess of air, Planas says). Belmonte’s trust in the nutty mechanic bore fruit in terms of million-peso savings in fuel budgets. Environment Sec. Mike Defensor and then-Energy Sec. Vince Perez heard about Khaos, too, and had their personal vehicles, a Ford E-150 and a Honda Accord, respectively, equipped. Defensor swears by 32 percent fuel savings; Perez, 50 percent. The Khaos brochure shows a photograph of show biz star Onemig Bondoc with a big smile for 30 percent fuel savings on his Jaguar.
    Since then Planas has set up three small factories in Metro Manila and sold over 20,000 chargers through a hundred dealers nationwide. He also exports to 35 countries, where the charger sells faster for environment-friendliness. The charger costs P6,500, installation included, on either fuel-injected or carburetor engines. No adjustment of idling or timing, except on some older cars. This month Planas will roll out a smaller, cheaper charger for motorcycles (P1,500-P1,900); by July, a version for diesel vehicles.
    Car repair shop owner Ogie Amada met Planas in October. He tried the charger on his car and immediately saved P2,000 a month driving from home in Angono, Rizal, to work in Sikatuna, Quezon City. He has since sold dozens of units to friends and customers. No complaints from them except this: "Why did you introduce us to Khaos only now?" * * *
    E-mail: jariusbondoc*workmail.com
    #23
    sana maging successful tayo.. wala na tayong pag asa sa oil price hike
    Feb 2005
    #24
    i was just at the "coding twice per day" thread and when i saw this sabi ko hayy nakow another april fools siguro, yun pala totoo. hahaha
    Feb 2005
    #25
    Quote Originally Posted by ts1n1ta
    Same here. But as always, curiosity killed my cat.
    #26
    pwede kaya sa trooper ito????
    #27
    Hindi ba reduced ang energy density dahil suspended ito sa non-fuel? Kumbaga, may extender.
    Pano na iyan kung CRDi ka tapos super fine mist ang spray ng injector mo? Baka hindi enough ang fuel na makarating?
    Just thinking out loud.
    #28
    baka di umubra sa new crdi engine like the new hilux vigo
    #29
    pang lumang klaseng oto lang?
    #30
    Read rsnalds' post. That fuel is usually used for generators and other industrial machines which are not really very sensitive to the fuel you put in. Hindi naman talaga ginagamit for vehicles ito sa ibang market.
    #31
    Quote Originally Posted by odell
    Sayang naman lagyan yung bagong oto, seguro sa mga may edad na oto pwede seguro..
    Yung mga gumagamit nito, ipromote nyo naman, what do you think about our local inventions na ngayon nag iinternational sale na....
    Sayang yung invention natin....
    Feb 2005
    #32
    water has no power
    #33
    He's the man...sana ganito parati ang nababasa ko tungkol sa mga Pinoys at sana mag succeed itong invention na 'to.... kaya para mga sa kapwa ko na may mga anak na .....ibuhos natin ang ating resources sa kanila para ma-maximize nila ang talent nila, para sa kinabukasan ,para sa Bayan. Ito yong mga klase ng Pinoy na mag-aangat ng Pilipinas sa kasalukuyang kinalalagyan.....
    #34
    Quote Originally Posted by Tacoma_34
    water has no power
    actually it does have power, you just need to covert it to steam.
    #35
    that was a long but informative read!
    langyang shell yan gustong bilhin pa ang formula. mabuti kung bigyan ng credit ung inventor. MGA SWAPANG!
    Apr 2005
    #36
    ask ko lang kung ano na nangyari sa fuel na ito. commercially available na ba? Saan ba pwede magpakarga?
    Feb 2005
    #37
    Adding water to diesel fuel has the same effect of using water to decoke the engine. Short term will give you good result as it will clean the combustion chamber. Long term use will give you problem: rust in the fuel system up to the injector, unless modified.
    #38
    may additives naman daw yung fuel-water mixture so i think yung na yunjg anti-corrosive/rust additive.
    pwede ito sa RF engine ko. san ba nakakabili?
    #39
    kumusta na kaya to?
    Mar 2005
    #40
    sana pigilan na yan baka mawalan pa ako ng pampaligo
"Filipino Iventor Selling Fuel That Is 50% Water"
