Results 1 to 8 of 8
    Feb 2003
    Im experimenting now with nitrous oxide on a diesel engine. Unlike a gas engine that will overheat and may self destruct when run too lean, a diesel engine runs cooler when leaned out. so... adding nitrous can actually save your engine. and, in theory, reduce smoke emission.
    I am also experimenting with lpg injection. initial tests show that engine power is increased but extremely black smoke is emitted and overheating occurs. Plus a really bad smell.
    I have yet to try combining both. But , again in theory, the nitrous will add enough air to neutralize the lpg. Thus, equalizing air/fuel mixture. Overall effect would be an increase in horsepower.
    Kaya lang... wala na akong pera para matuloy ang experiment!
    pls. send donations to......
    But seriously, if anyone is interested pls contact me. lalo na kung sinoman ang may nitrous system dyan. Salamat po.
    Meron nang NOs para sa diesel engines.
    Feb 2003
    ows, crap naiwan na naman ako ng balita.
    uy rod..delikado yang lpg thingie na yan.....
    pero ok lang...may pera ka naman eh..ehrherhehr
    Nahilo ko sa mga theory ni Rod, grabe parang scientist! Hehehe.
    ako rin eh...
    balitaan mo na lang kami sa experiment mo, Rod!
    hehehehe
    Rod, pare try these links....
    http://www.bankspower.com/tech_nitrousoxide.cfm
    http://www.duramax.bizhosting.com/My..._injection.htm
    taken from NOSWIZARD.COM
    Q11) Does nitrous work on Diesel I Turbo engines?
    A11) YES! and with much better results for a given power increase than a petrol engine, as a diesel does not have an ignition system like a petrol engine and consequently the power output is not reduced by a poor condition ignition system, also the timing of the ignition sequence is not as crucial on a diesel which not only helps the power output, but also reliability. With a petrol engine detonation can soon become a limiting factor to the power output, but as tar as I can tell this is not the case on a diesel as they actually run on detonation and as a consequence are built stronger which is another reliability bonus. The biggest advantage of a diesel over a petrol engine is the diesels lack of acceleration ability, but with N20 injection this shortcoming is dis_proportionately improved. Cost is another area where a diesel has an advantage over an equivalent petrol engine, as the basic N20 systems for a diesel does not need a filet control system as a petrol engine does, which reduces the cost of a similar diesel system by approx £100. The only limiting factor is how much fuel the engine wastes, and how much extra can be added.
    HTH!!! Balitaan mo na lang kami :D :D :D
    Feb 2003
    very true yung fuel. when I ran nos on my diesel plus lpg nag adjust din ako ng fuel pump. estimate ko 2kms/l. power was amazing and so was the pollution. zero visibility through my exhaust.
Diesel nitrous
