Results 1 to 6 of 6
    Aug 2005
    From the manual, 45 liters ang fuel tank.
    Pag kumakarga ako ng nakailaw na ang low fuel warning, nasa 37.xx liters ang pinaka konti ko na naikakarga to full tank.
    Pinaka marami ay nasa 39.xx liters.
    So kung umilaw, mayroon pang mga 7 to 8 liters na gas sa tank.
    Sa mga may Avanza, ano ang observation ninyo? Ilan liters pa pag umilaw na ang low fuel warning?
    Nov 2006
    That is perfectly normal, the manual says the actual computed volume of the fuel tank and the fuel sensor might have been calibrated to that level to lit when it only remain about that liters of gas left.
    Sep 2005
    once pa lang ako nakapagkarga na umilaw yung low fuel warning.. parati ko karga eh nasa 1/4 or below 1/4.. anywhere from 34 to 37 liters.
    sir sagad po ba yung pagpa fulltank mo?
    kas pag automatic (yung pump automatic namamatay pag puno na) may mga 5-10 liters pa na pwedeng idagdag pag manual (isasagad ng gasoline boy) ang pag lagay .. puno hanggang sa tip ng tank ..
    Sep 2004
    ^^^ Ha?? I seriously doubt kung pwede ka pang magdagdag ng up to 10 liters kung nag-stop na automatically yung pump.
    In my Accord, normally full tank ako parati. The pump attendant normally sets the pump to automatic, pero parati kong pinapasagad. Less than 2 liters lang ang nadadagdag.
    Usually may naka-reserve na 8 to 10 L pag nag-light na yung fuel indicator. This should help you reach the nearest gas station for a refill.
    Yung pagsagad ng gas hanggang tip, afaik mga 2-3 L na lang talaga ang pwedeng idagdag pag nag-release na yung automatic pump.
Avanza Low Fuel Warning
