View Poll Results: BEST Unleaded Fuel: Shell, Petron or Caltex
Voters
127. You may not vote on this poll
  • Shell
    40 31.50%
  • Petron
    46 36.22%
  • Caltex
    11 8.66%
  • Total
    4 3.15%
  • Sea Oil
    13 10.24%
  • Uni Oil
    9 7.09%
  • Others
    4 3.15%
Page 13 of 17 FirstFirst ... 391011121314151617 LastLast
Results 241 to 260 of 488
    Mar 2005
    If you have a car na once a month or more bago ka mag gas use non ethanol blend dahil i think 3 weeks meron nang contamination ang ethanol fuel. Sa big bikes na bihira gamitin i use blaze baka ma contaminate at masira pa ang aking kabit. Hehe. Also multiple vehicles or once a week coding car should be on non ethanol imho
    Jun 2015
    Recently tried Petron Blaze 100 and my 3-cylinder engine likes it. Nawala ang pings.
    I'll take advantage while it's still below 40 /l.
    sent via Tapatalk
    Oct 2015
    sent via Tapatalk
    Ano auto mo sir?? Ilang ron yun??
    Jun 2015
    Mirage HB. 100 ron ang Blaze.
    Actually as per the owner's manual, around 90 ron lang ang required.
    My usual gas is FuelSave or nitro+ depende sa availability pero nagsimulang mag-ping after pakargahan one time sa Shell Naga Road, Las Pinas. May problema yata fuel nila dahil sa ibang Shell station naman never akong nagkaproblem.
    Anyways, Blaze muna ako to clean out the engine habang mura pa.
    sent via Tapatalk
    Jul 2014
    sent via Tapatalk
    Sa Shell Naga ako nagpapagas for the longest time. Never experienced knocks/pings with their 91 RON.
    Dec 2009
    Hindi ba maganda ang fuel ng Petron? Naka experience kasi ako ng engine knock simula nung gumamit ako ng 91 super xtra. Nung nag shift ako sa 93 xtra advance meron padin. Pero nung caltex silver ginagamit ko wala namang engine knock. Hmmm
    Sent from my H220 using Tapatalk
    Aug 2015
    Quote Originally Posted by radz15 View Post
    Ganyan din sakin sir yung 91 super xtra may engine knock lalo na kapag nagshift ng gears. Yung 95 xcs meron pa ring konti pero di na katulad ng sa 91. Ok ba ang gas ng caltex? Eh shell kaya?
    Btw sa petron greenhills ako parati nagpapagas. Yung katapat niya caltex fronting edsa. Binabaha ba dun? Baka kasi yun ang culprit?
    Quote Originally Posted by Dende View Post
    mine is different.
    after years and years of using Total Excellium, an officemate asked me to try the Petron variant, which is XCS because of the Euro IV characteristics.
    mas matipid sya ngayon, and mas smoother yung acceleration and idling. i used to average around 10.5 kpl, but now, i usually average around 11.8-12 kpl (Altis MT).
    mas nakaka experience pa nga ako ng engine knocks on shifting of gears dun sa excellium, but now, nawala.
    btw, petron has 93 octane. kung may engine knocks if you are using the 91 octane, try to use the 93 octane...
    some of you maybe asking bakit ko gamit yung 95 octane whereas pwede naman yung 91-93 octane....wala lang, feel ko lang... i just need the power and smoother acceleration that the 95 octane variant gives. and sa experience ko, mas matipid yung 95 octane compared to the 91 octane, imho.
    Dec 2009
    Sa experience ko ok naman ang caltex. Sabi nila shell daw ang pinaka malinis. Try ko yung 95 octane ng caltex.
    Nov 2014
    first time ko pakarga few weeks ago ng Php500(12L) na petron blaze, parang laging gusto shift agad sa high gear nung Erti namin pero yung FC parang pareho lang with 91-95 RON.
    Mas angat ng kaunti sa FC yung 95RON sa amin
    Dec 2009
    uploadfromtaptalk1451300274651.jpg akala ko 93ron yung xtra advance. Hmmm..
    Jun 2015
    Onga 93ron ang extra advance at 91ron yung super xtra.
    sent via Tapatalk
    Dec 2009
    sent via Tapatalk
    Bat nakalagay dyan eh 91 lang saka nagtataka din ako sa blaze dapat 100 ron pero 97 lang nalalagay
    Sa big 3 Shell ako for my mc's and 1.8G Altis.
    Apr 2009
    The best fuel for your car is written in your owner's manual. If your manual says the minimum requirement is 91RON, then you can use any fuel with octane rating 91 RON up. Brand of fuel is already subjective accdg to your preference and budget. Any fuel you use that has a lower rating than what is stated in your manual will definitely make your engine knock.... Of course fuel economy still depends on how you drive and the volume of traffic you encounter daily rather on the type/brand of fuel you use....
    the names these gas companies give their products... designed to sell.
    but i look at the octane ratings that are pasted on the pump.
    as to recommended octane rating.. some manufacturers now print that their car does 91 octane.. but a few years before that, their manuals had 93 or 95 octane..
    i think the car's EFI can adjust itself, to do 91 octane, but the recommended (optimum-wise) is 93 or 95..
    owner will have to decide what octane it is, that gives them better oomph and mileage..
    when my wigo was new, i used 91 octane and the engine seemed to like it.
    after 5K, i tried 95 octane. my engine seemed to like it, and my km/li improved. but i wasn't sure what did it.. was it the shift from 91 to 95? or was it that the engine was finally broken in..?
    so now, after a couple of thousand km, i shifted back to 91. i am now observing whether i will still get the "better km/li" figures..
    Dec 2009
    Sa suzuki Celerio ko 90ron ang minimum requirement. Laging 91ron lang pinapa karga ko pero nung naging 4k na mileage ko bigla nalang nakaramdam ng engine knock especially sa Petron 91ron. Nung sinubukan kong mag 95ron nawala Engine knock kaya ngayon lagi ng 95ron pinapakarga ko para sure walang engine knock.
    bring it to the shop, po.
    maybe you need a tune-up..
    i read somewhere, that not all engine knocks are audible. just because they may not be heard, does not mean they are not causing trouble to the engine.
    Dec 2009
    Actually the first time ko maramdaman yung engine knock dinala ko sa casa right away. After thorough check up and test drive wala naman daw prob so the mechanic suggested na wag na daw ako mag Petron at shell nalang daw gamitin ko. After using shell 91ron dramatically na lessen yung engine knock at nung nag 95ron nako totally nawala na yung engine knock. Yung ibang ka group ko sa Celerio club nakaka experience din ng engine knock sa 91ron kaya suggest nila mag 95ron nalang. Baka hindi lang maganda quality ng fuel sa pinas kaya kahit above sa minimum required ron eh nag e-engine knock padin.
    perhaps carbon and sludge deposits in the cylinders result to higher compression ratios, necessitating higher octane ratings.
    try the italian tune-up, and see if the knocking disappears.
