Page 201 of 211 FirstFirst ... 101151191197198199200201202203204205 ... LastLast
Results 4,001 to 4,020 of 4201
    May 2010
    #4001
    Hi Mile2 - aling o-ring pinapalitan mo sa vaporizer mo? yun vaporizer ko kasi may tagas kunti sa bandang likod. Nanggagaling don sa may 2 blue plastic tube kung saan connected yun rubber hose connected sa coolant. natry ko na higpitan un clamp sa rubber hose pero non kinapa ko galing don sa loob ng vaporizer yun tagas. kay greenfuel ka bili ng o-ring or kay xoom?
    salamat.
    Aug 2006
    #4002
    Quote Originally Posted by Louga View Post
    salamat.
    Yes, it was the O-ring for the 2 blue elbow tubes, got them at GreenFuel.
    #4003
    Quote Originally Posted by Mile2 View Post
    You're still; using the original vaporizer on your Innova? Had to change mine a couple of years ago at Greenfuel.
    On a side note, buying a second hand Innova gas a/t (heck or even a Fort 2.7) then convert it to LPG is something i plan to do in the future. Looks like a good project for a family car.
    Jun 2005
    #4004
    I thought that if an engine is built to run on unleaded fuel, valve recession on lpg should not be an issue. Why is it that xoom offers an additive that would prevent valve recession?
    Is there really a risk of engine damage because of lpg (aside from those running too lean due to improper tuning)?
    #4005
    Quote Originally Posted by sirkosero View Post
    Most of todays cars are equipped with Hardened valves and valve seats that can resist high temperatures and sturdy enough to operate with LPG as its fuel.
    It does not mean that LPG converted vehicles are required to have Valve Saver Fluids installed with the kit yet its a very good precautionary measure to ensure longevity for our engine. Valve seat recession does not happen in an instant it occurs overtime usually reaching mileages of 100,000km - 150,000km before showing real symptoms. Our fuel (gasoline) when injected gives natural lubrication to the valves since its sprayed in liquid form.
    LPG on the other hand is injected in gas form and is dry. Valve Saver Fluid adds the lubrication that is missing from LPG thus protecting the Valve seats PLUS its also cleans fuel injectors and fuel system. Hope this helps! Cheers!
    Jun 2005
    #4006
    Quote Originally Posted by XOOMaster View Post
    Thanks bro! I saw it in your fb page thats why im curious. Btw, please update the picture gallery : -)
    I thought there is a cycle of using petrol in SGI systems wherein petrol is sprayed every few minutes. Isnt that supposed to provide some sort of lubrication already or is it just to ensure that injectors remain unclogged?
    #4007
    We have that feature in our software and yes you are correct thsi will already be enough to add lubrication. Though oddly most of our clients do not want it activated as they say it consumes their Petrol faster which is really a bit odd.
    I used the Valve Saver on my Forester just to be safe and my usage cycle is 3.5 weeks on LPG the rest of .5 I use Petrol. I do this to make sure my injectors remain in tip top condition and more importantly I get to refresh or refuel by Petrol. (our Petrol or Gasoline now a days have Ethanol which gets stale in about a month of none usage and will lose its Octane power.)
    Let me know how I can assist you further. you may also send me a message in our FB site. Cheers!
    Oct 2007
    #4008
    On motorcycles converted to lpg one feature is the injection of 2t oil for lubrication.
    Would adding 2t to your gasoline a good idea for cars with lpg kits?
    #4009
    Quote Originally Posted by mark_t View Post
    Definitely a bad idea.
    Jun 2008
    #4010
    * XoomMaster
    I understand you have converted a Mazda 3, may I know if you experienced an idling issue on this make? If its possible, can I have the owner contact details. Thanks.
    Jul 2011
    #4011
    Sa lpg tank 2 ang option diba, ung donut at cylinder, malaki po ba diff sa price at same po ba ung volume ng lpg na pwede ikarga
    #4012
    On the tank type, the donut tank is more expensive by around 1-2K before. I don't know now. In terms of capacity, each design has several capacities depending on the trunk size but i think the cylinder tank has the ability for a larger capacity.
    Jun 2006
    #4013
    My sgi lpg lovelife suddenly developed a leak , it leaked thru the gas solenoid near the tank.
    Unfortunately those fracking people at greenfuel skimped on the plastic flexible hose that would vent the leak outside the car. Did not notice this before because that part was hidden behind the tank.
    Its a good thing that xoom offers the use of its leak detector and will repair and rectify the flexible plastic hose problem.
    Anybody knows where i can buy an lpg leak detector? The ones at sulit are very expensive.
    Jun 2005
    #4014
    Quote Originally Posted by shibby75 View Post
    Did you smell the leak from inside the cabin? Delikado yata yan ah.
    Was this your first problem with lpg? How long have you had yours fitted?
    Jun 2006
    #4015
    My sgi already leaked twice, first is at the solenoid inside the engine bay,di ko naamoy, napansin ko na lang nung nag 4km/l ang oto.
    This time sa compartment, di ko din naamoy, napansin ko lang nung hinika ako last night which is matagal na ako hindi nagka asthma attack.
    Pina check ko sa xoom, Yon may leak nga sa trunk. Yung flexible hose that would divert any leak outside the car was cut short by greenfuel (tinipid!).
    My sgi would be on its 3rd year this august. I check for leak by spraying with soap and water weekly, pero this time leak detector lang ang nakakita.
    #4016
    This is why I do not anymore recommend Greenfuel for Auto-LPG installation and maintenance. These days I recommend XOOM.
    #4017
    Hi Raven,
    I actually have not converted a Mazda 3 yet. We were able to however calibrate and replace injectors on a Mazda 3. In general it is not a very sensitive car. I think that our Zavoli 'SMILE' kit will have no problems with it. I've used the same kit on a Subaru Forester and have excellent performance and results with it. I'm confident you'll be very satisfied with it as well.
    Cheers!
    Nick
    Quote Originally Posted by raven1925 View Post
    * XoomMaster
    May 2010
    #4018
    Nagbackflow yun coolant ko habang nagpapahangin ako ng gulong sa gas station. Lakas ng tagas ng coolant sa reservoir at nabawasan yun nasa radiator. Pinatay ko muna makina at pinalamig at dinagdagan na lng ulit ng tubig non mekaniko. Pansin ko super lamig non vaporizer at yun mga hoses. Parang biglang pumalya yun vaporizer ko. After ko restart ayun uminit n naman at non change over parang lunod so nag gas muna ako til now. Hindi naman tumaas temp guage ko. Buti na lang at andon ako sa gas station at hindi habang tumatakbo or else baka matuyuan radiator ko at overheat.
    Punta ako kay Xoom bukas at papalitan ko na lang ng mas magandang vaporizer para peace of mind. May tagas na din kasi yun. 2.5yrs old na kit ko at ito lang ulit yun major problem after maresolve yun lack of power.
    May 2010
    #4019
    updates:
    Kahapon napalitan na yun vaporizer ko. Zavoli brand yun pinalit and will last 5yrs daw kasi ito ata yun best kita nila so far at kinakabit sa mga private car. Pinalitan din yun water/coolant hose kasi luma na kaso lang isa lang yun pinalitan at natira yun isang luma kasi ok pa din daw. Kanina lang napansin ko nagleak yun coolang ko at ayun nagcrack yun lumang hose kasi parang maiksi na at nabanat. Buti na lang at pinadala sakin un extra hose na natira at pinapalitan ko na lang sa mekaniko sa shell. Good thing kasi lage ko inspect kit ko
    Pansin same brand lang yun luma at yun replacement hose so I'm wondering baka hindi din tumagal ito...sana may hose na kagaya ng pang radiator talaga para long lasting
    So far ok na ulit kit ko. Recalibrate lang kunti at leak test. Inayos na din nila yun sala-salabat na wiring ko at nilagyan ng bakal na brace yun ECU ko sa ilalamin manebela para hindi umuuga.
    Salamat ulit Zoom. Ok workmanship (except don sa isang hose na dapat pinalitan na lang din) at maasikaso mga technician.
    Feb 2013
    #4020
    * louga, magkano inabot nung replacement parts mo? thanks.
Auto-LPG Conversion Thread
