The smell would be normal since venturi lpg systems do have some "leak-down" from the intake manifold.
Quote Originally Posted by n5110 View Post
parang hinde normal ito, baka may leak better have it check boss. yung sa akin i can see white residue sa vaporizer pero walang amoy, not sure if this is leak. minomonitor ko pa.
about the tachometer reading parang hinde naka adjust ng tama yan, yung sa akin naka set sa 700-800 idle without AC pag naka AC naman di nalalayo, minsan nag ffluctuate yung idle, nag ddrop at 400 pero madali naman bumabalik sa 700 with or without AC. baka airfilter niyo madumi na.
tnx GH and n5110. just cleaned the air filter recently pero ganun pa rin rpm reading. the air filter has 2500km mileage already. is the rpm setting should be the same for both gasoline and lpg? running on gasoline, my rpm is 700 at idle.
