hmmm..so your car was installed with an EFI kit? The best way to make adjustments is to check your exhaust readings through a gas analyzer just to check if your running rich or lean. Then tune-up the car accordingly so the mixture is just right even with or with-out load. That should solve your problems of low RPM.
Any CleanFuel Auto LPG refilling station has gas analyzer apparatus - It's FREE. ( SGI kits not included in this promo )
They will calibrate and clean your air filter as long as you refill from their station.
Mine is SGI, so I just have my air filter cleaned.![]()
Tanong lang.... I presume the shops don't have this. Is a "dual-fuel" tank available already, somewhere? A single tank with two separate compartments, one for gas, the other for LPG. Being separated, pipes and other interfaces will go into their respective systems.
Since this will replace our existing tank, this resolves the tank placement issues.
Or maybe this is just a figment of my imagination.
